head gasket
tegrakid06
Posted
im not sure but i think i have a blown head gasket there is oil leaking out of the coner and there is white somke coming out the exhaust and it boggs down when u give it gas and it runs slugish and the tip of my spark plugs are wet. can yall tell me what else it could be or if it is a blown head gasket
Posted
That sounds like a head gasket problem. I don't know too much about them but when I was (briefly) looking into them the smoke when you accelerate was one sign they listed.
Posted
Yep that is a blown head gasket. The white smoke is burning anti-freeze. I would suggest changing it at the soonest opportunity.
Posted
Yea, hurry on that one. Once enough of the gasket blows out you'll lose pressure/compression, whatever and then you'll be stuck in a parking lot somewhere. My exp with head gaskets is they generally haven't failed in transit, but when you go to start it back up again it won't fire
