Toy Civic Posted February 4, 2007 Posted February 4, 2007 I've seen the info about the 02-06 Hondas having speedo accuracy issues and that a class action settlement was reached. It appears that the inaccuracy was 3-4%. Here is more food for thought. This IS also a notorious problem with 1992-2000 Civics and 1994-2001 Integras. Case in point. I'm the original owner of my 1995 Civic EX Coupe. When new, it had the 185/60/14 tires. I found my speedo to be off by 10% per the speedo dyno check I had done at the time. It was reading 10% FASTER than actual speed. For the first 7 years, I dealt with it and mentally compensated by going 75-80 MPH to acheive a true speed of 68-73 MPH. With this 10% inaccuracy this also brings into question the odometer readings.........racking up mileage faster, as well as false 0-60 times published in the automotive press. For the past 5 years, I have had 205/40/17 tires, and my speedo and odometer accuracy is PERFECT. HMMMMMMMMMMMMMMMMMMM!!!!!!!!!?????????
Ben. Posted February 4, 2007 Posted February 4, 2007 I don't see how bigger-than-factory-rims are gonna make it perfect..but.. That's just you.
Toy Civic Posted February 7, 2007 Author Posted February 7, 2007 I don't see how bigger-than-factory-rims are gonna make it perfect..but..That's just you. Take 2 circles, one larger and one smaller. Which one will travel farther a flat surface upon a full 360 degree rotation? Answer: the larger one will. Simple math. I've got speedo dyno checks to prove my point.
Ben. Posted February 7, 2007 Posted February 7, 2007 That's all well and good, I'm just talking noise.
Pyrorocketeer Posted February 7, 2007 Posted February 7, 2007 it isn't the rims that changed your tire size... its the size of tire.
TS John Posted February 7, 2007 Posted February 7, 2007 Well, it's sort of both. It's all down to the diameter overall. I've heard of that, Toy Civic. Specifically, I've heard that Hondas from that year come stock off by about 10% (erring high) and that by going up in overall wheel size to the standard for 17" rims corrects the problem perfectly.
