Trunks Posted February 1, 2007 Posted February 1, 2007 ok so i installed the intake no probs. now i need to bolt the pipe to the body but i have ABS so the hole is being used by the unit. for now i just tied it in place. wondering if thats ok?
airjordan223 Posted February 1, 2007 Posted February 1, 2007 if you did it right, the bolts should line up with the stock bolt holes
coolcat467 Posted February 1, 2007 Posted February 1, 2007 Are you sure you put it in right? Like airjordan said, it should bolt right up. I have a 97 civic and the intake lines right up, they are basically the same thing.
Trunks Posted February 1, 2007 Author Posted February 1, 2007 yeah it does line up but the hole is being used by my ABS fuse box.
CleanGSR Posted February 1, 2007 Posted February 1, 2007 Can you not share the location? Unbolt the bracket for the fuse box, stick the "tab under the hole, and rebolt the fuse box bracket back down with the intake mounted under it. Hope that makes sense.
