adjusting height of headlights
turbo_d15b
Posted
okay so i bought some tyc headlights and i don't know how to adjust the height of the beam. Right now i am shooting it way in the air like a highbeam? anyone with suggestions would be really helpful thanks.
Posted
i know on stock headlights there are bolts and tabs and stuff that you can adjust. if they connect up to all the stock connections it should be the same way you would adjust your stock lights, and it tells you how to adjust those in your cars manual or a haynes manual.
Posted
Some adjustments can be made with just the bolts that secure them to the car. Then there are usually aiming bolts that you can turn that your manual will point you towards.
Posted
there are two long bolts by the high beam part...it might be those bolts? not sure....there are two of them
Posted
i can't remmber if this was on my truck or my car but i think on honda's you can only adjust tehm up and down so i guess i would just mark where they were originally so you can put everything back the way it was in case its not the right thing to adjust and then just move it around until you find the right ones
