This is one baaadass SRT4.
Ben.
Posted
Idle.
idle clip
Vs Z06 corvettes:
vs two vettes
"1) 2007 427ci Corvette z06
Mods are as follows:
Corsa Catback Exhaust
2) 2004 AMS built SRT-4
AMS37r Turbo Kit
AMS Built Head
AMS Built Block
AMS Tuned
AMS UPP Pipe
AMS Lower IC Pipe
AMS 4" Intake
Oliver Rods
Wiseco Pistons .02" over
O-Ringed Block
Stock Head Gasket
Form-N-Function Perf Intake Mani
DCR Billet Oil Gear
MADI Crank
SI Valves 1mm over
1g Crane Springs
Crower S3 Cams
AEM EMS
MSD Ignition
1600cc Injectors
Twin 290lph Fuel Pumps
Clutch Master FX700
AGP Race FMIC
3) 2004 408ci Corvette z06
LS2 403 built by Xtreme Horsepower, 4" forged eagle crank, forged eagle H beam rods, ARP rod bolts, ARP main bolts, 4.005" wiseco pistons -8CC, rings file fitted for N20, everthing was balanced blue printed, clearance, etc. I was told CR on the sb is 10.8:1 if i were using stock LS1 heads unmilled.
Dart 225cc/80cc Stg3 hand ported and hand finished bob at precision porting and coatings, coated, 2.055/1.60, 62cc chambers, [email protected], patriot gold dual springs
ARP head bolts
ARP crank bolt
powebond 25% underdriven pulley
DTP STG2 23X/24X lift, .60x/.60x, 112+2, installed -6 Daves total performance in Ohio
DTP ported fast 90 Daves total performance in Ohio
S2 ported LS2 90
billet double roller timing set
LS2 lifters
comp push rods
LS6 rockers
42# SVO injectors
vortex true ram air
BPP carbon fiber air bridge
Posted
i hate neons with a passion, but that thing is pretty badass. he destoryed those vettes. too bad it blew though...
Posted
major pwnage. sad that it can't handle the power.
to pino's vid: that's a lot of torque...
the input shaft has nothing to do with power
stock SRT's break them
it connects the shift lever to the actually tranny to tell it which gear is it in
Posted
Love the Skittle! That turbo lags like a biotch!
It's not lag, in that car.
It's foreplay. ;)
Posted
Surely you weren't expecting traction in a fwd domestic car with balls.
Posted
um what? the input shaft is the splined one sticking out of your bellhousing, that goes into your clutch.
Posted
i was gonna say , hahaha , pyro took the words right out of me. and if you really wanna get technical , its the mainshaft.
