nickf829 Posted December 29, 2006 Share Posted December 29, 2006 I changed my oil and put 1/3 can of seafoam in just to give it a shot, my question is, do I need to change the oil with the seafoam in it after a few hundred miles, or will it be ok to leave it in for the next 3000 miles? Link to comment Share on other sites More sharing options...
compuvision02 Posted December 29, 2006 Share Posted December 29, 2006 It is supposed to "be in there," but it isn't really in there. It is supposed to burn off after a couple minutes from what I remember. Should cause a lot of smoke then get back to normal. Link to comment Share on other sites More sharing options...
lilSikSoL Posted December 29, 2006 Share Posted December 29, 2006 I changed my oil and put 1/3 can of seafoam in just to give it a shot, my question is, do I need to change the oil with the seafoam in it after a few hundred miles, or will it be ok to leave it in for the next 3000 miles? man ...that crap works.....i got me a can and 3 cups...i fiild all 3 half way...first one you wanna do is gas tank.. run the car till smoke stops....second do the intake mani...smokes for a 5-10 min..last one the motor.. after the sea foam is in the motor take it for a freeway run (its gonna smoke like hell ) then come back change the oil check it in a day or 2 if the oil feels thin change it onece more till its back 2 normal.good luck.. Link to comment Share on other sites More sharing options...
