ALL MOTOR B16 Monster, Need Insight Before I Start
DTC.Monster
So.. I have a B16A2 BLock........... Starting to build it.. And I wanted to Build this motor to be an all motor beast..
Well These Were My Ideas...
If I Resleeve it and increase the bore to About 84 mm. Not too Big..
And Stroke the Motor to about 87mm. to Increase the Displacement... I Therefore turn the 1.6L To about a little over a 1.9L.. Also with PCT Pistons for the High Compression..
Because I want an all motor car, looking as a stock B16, Would this be too much strain on the motor..
Chances are I will do it anyway, but I want to kno wht I should be prepared for..
Thanks.
always knew you smoked crack. finally , confirmation , lol.
Thanks.
get yourself some B16B(PCT) pistons. get yourself a GSR crank , order custom rods for proper piston to deck(calculator says 128.35mm rods). this will give you 12.1:1 compression ratio even. that matched with built head and cams would be a fun engine. technically , this would be a stroker. but stock bore. now that very same setup , only the block sleeved for an 84mm bore , would give you 12.8:1 , instead of 12.1:1. so you see , boring them out doesnt have as much effect. but i always say , boring them out is not as hard on the engine as stroking them further.
Thank you for the one person to help me.. Other than that.. LMAO at this dude smokin crack..
f*ck you ..SSR...
Can't put OEM non B20 pistons in an 84mm bore.
Might as well get a B20 block. Cheaper than resleeving, then you can use the 89mm crank without killing your powerband and longevity.
what are you talking about shorter? like it can't handle the length of stroke? and get different pistons......
EDIT : or even better yet, actually get a decent motor that you can modify, make good power, and actually have it last..... how long will 350+ hp last in a honda.... not nearly as long as 350hp + in a V8
Ok. Its time for you to hop out of this thread.
1. The block is shorter. You do know the definition of shorter right?
2. The tech43 stroker kit for the B16 (or piece together your own kit for a few more hundred). It uses an 89mm crank, short ass rods, and craptastical pistons (high pin, almost skirtless). Now take the R/S (not R/S ratio) along with the piston design and you have yourself a 10k engine that peaks at a lower RPM than an LS/VTEC and isn't really good for much.
EDIT: Notice I told him to go with a B20 block? 350whp Hondas have been driving around daily for years now. Hop onto H-T and you'll see quite a few 350whp builds that have been driven every day since the late 90's. Pretty good considering 500whp on a built pump gas engine was hard to come by at the start of the century.
LOL guess what there have been many cars running 350 stock hp for quite a few years now too! I could really care less what potential honda's have, cause they will never be as reliable as its equal v8.
I don't want to argue with some honduh teen about numbers, I came here to learn a little more about boosting, but half the toolbags on here don't know crap. you included.
