1996 integra motor swap
njkid
Posted
Ok so i finally got a motor for my car. I got a b16 siR motor. Now i was wondering what I am going to have to do to switch over to obd1 being that the motor is obd1 and my car is obd2? Also my car is an
LS and i was also wondering what i am going to have to do to run vtec wires? And is their anything else that i will have to change? I was told something with the plugs is going to have to be changed is this true? thanks.
Posted
you need a b16 ecu , and an obd2-obd1 jumper. theres a sensor under the lower timing belt cover , CKF , crank fluctuation sensor , obd1 doesnt have this , so the plug will be left off as the b16 doesnt have one. use your distributor that is on the car now. all sensors will be the same , take the plugs off each sensor of your LS , and plug them onto the b16 sensors.
Posted
i have an obd2-obd1 jumper harness if there is any need for it. i have a 00' GS-R Swap in my 96' civic HX. have with all of it i know i did. about to put in a 95 hatch. sweet ridin all night long
