Pyrorocketeer Posted December 24, 2006 Share Posted December 24, 2006 Well....I've got some bad news.... Today when I was comming home from the mall, my engine developed a bad tick. I needed to get home, so I kept running it..... It lost 50% of its power, and I started to slow wayyy down. The tick turned into a knock, the knock turned into a boom.....with lots of smoke. :( The poor ole girl is sitting along the road waitin to be picked up by my brother and I tonight. Engine needs tore down and inspected.... I'll post the damages later tonight, or tomorrow sometime..... :( Link to comment Share on other sites More sharing options...
Ben. Posted December 25, 2006 Share Posted December 25, 2006 That's crapty, especially this particular day. Link to comment Share on other sites More sharing options...
..SSR.. Posted December 25, 2006 Share Posted December 25, 2006 Was the knock in the top or bottom? Or could you tell since you were driving? Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted December 25, 2006 Author Share Posted December 25, 2006 I neither have a top nor bottom. I do have a left and a right. Top is crank, bottom is cam..... lol Link to comment Share on other sites More sharing options...
Ben. Posted December 25, 2006 Share Posted December 25, 2006 I neither have a top nor bottom. I do have a left and a right. Top is crank, bottom is cam..... lol he drives teh beetle! Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted December 25, 2006 Author Share Posted December 25, 2006 Pulled the engine this afternoon, and well its worse than I hoped.......I managed to put a rod through the top of my case.... :( what a merry christmas this one is turning out to be...... Link to comment Share on other sites More sharing options...
TS John Posted December 27, 2006 Share Posted December 27, 2006 Bummer, man. I too am feeling the sting of car problems this holiday (see my thread in the del sol section about my accident). Hopefully you can get it all sorted soon enough. Good luck. Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted December 27, 2006 Author Share Posted December 27, 2006 Sorry to hear about your wreck John. I hope you get all that stuff sorted out in your favor. I'm already rounding stuff up for a rebuild..... I have a used case coming soon ($50) and ordering all the parts for a rebuild tomorrow. stock crank and rods. 2mm bigger pistons little hotter of a cam increased compression by taking out the cylinder shims. blueprint my oil pump should be good for a few more hp, and a lot better gas mileage. I don't have the money for a serious build at the moment, so i'll just stick with just over stock. Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted December 30, 2006 Author Share Posted December 30, 2006 Well today I had some spare time, so I decided to tear into that blown engine to get all the salvageable parts off of it. To my surprise, there wasn't many.... :( took off cooling fan to get a better look at the damage done to the case.... note the 2 holes in the block.... lol took off heads to find this.... cracked between the valves due to overheating at one point in its recent life. removed cylinders to find a bunch of things.....lol broken piston..... broken rod.... Busted into 4 pieces, but the rod bolts didn't fail! broken cam..... and the list goes on.... the crank is now shot, the oil pump broke.... no longer can use the oil cooler (shards of metal could be in it) We (dad and I) aren't sure exactly why it failed the way it did tho. The rod journal is obviously burnt, so it was starved of oil, burnt the bearings, and lead to its demise..... Engine case is on its way, and the rest of the parts will be ordered within the next week. :( Link to comment Share on other sites More sharing options...
Monty Posted December 30, 2006 Share Posted December 30, 2006 Wow, that's the worst I've ever seen, especially since it was running fine, then all the sudden, you're driving poop on wheels. Link to comment Share on other sites More sharing options...
Ben. Posted December 31, 2006 Share Posted December 31, 2006 Wow. That's awful. Link to comment Share on other sites More sharing options...
cranny Posted December 31, 2006 Share Posted December 31, 2006 thats not near the worst ive seen but its definitly ugly pyro. i cant beleve that stock rod broke in 4 pieces before ther bolts let go , lol , thats insane pyro. Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted December 31, 2006 Author Share Posted December 31, 2006 i couldn't believe it either lol those rod bolts are weak as hell too! Link to comment Share on other sites More sharing options...
TS John Posted December 31, 2006 Share Posted December 31, 2006 Jeez, man. Is that even salvagable, or would it be cheaper just to get a new engine? Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted December 31, 2006 Author Share Posted December 31, 2006 nope nothing is, maybe a rod or 2, and 2 pistons, but thats it. New case should be here soon, and I have all new internals comming. Link to comment Share on other sites More sharing options...
cranny Posted January 1, 2007 Share Posted January 1, 2007 yeah head looks mint still suprisingly enough , lol. Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted January 1, 2007 Author Share Posted January 1, 2007 The head is cracked between the valves, so its pretty much scrap too. The other one is still good tho. Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted January 4, 2007 Author Share Posted January 4, 2007 Ordered a bunch of sh!t tonight.... New German 69mm crank New German rods Engle 110 cam and lifters Straight cut, adjustible, timing gear set 87mm piston and cylinder set. New heads ported and polished 40mm/37.5mm intake/exhaust valves HD valve springs and titanium keepers 12lb lightened flywheel to be ordered.... new 26mm full flow oil pump, and oil filter kit. new oil cooler new bearings (main, cam, and rod) and new engine seals I have so much performance stuff i wanted to buy too, that I just can't afford at the moment.... :( Link to comment Share on other sites More sharing options...
cranny Posted January 4, 2007 Share Posted January 4, 2007 woohooo , love new goodies. Link to comment Share on other sites More sharing options...
