Towing a Fit
You can tow anything behind an RV if the RV is big enough and the car is set up properly. I have a friend that used to tow his mini-van and then bought a jeep and tows that now. A fit would be small enough. If you can't put it inside, just put it on the roof-rack.
Nothing wrong with flat towing... And if you're set up right, it's 100% legal unlike dolly-towing. If your car hangs off the dolly more than 4 feet it is illegal unles you hook up the brake lights to your car, or have some magnetic ones or whatever on the back. If you don't, you're illegal. And if you're going to go to all that trouble, you may as well do it right and flat tow it.
