remote operation
EGx94
Merry Christmas everyone!
I got a problem with my mom's 98 accord ex remote door controls. she needs to press button several times to open it. we changed batteries but to no avail. went to honda dealership and they tried to sell her a new remote for $80 and they will program it. i was thinking the remote kinda got out of sync. throughout the years & it just needs to be reprogrammed or resync. i remembered a similar prob ages ago with my avital alarm, one resyncs it by turning on ignition & pressing a button on the remote then turning off ignition. i tried this but it didnt work. any ideas or input is greatly appreciated. thanks in advance...
Pages 22-191 and 22-192 in the 1998 Accord service manual contain transmitter
troubleshooting and programming information. It says that pressing the lock or
unlock button five or six times will "reset" the transmitter. You can also
"rewrite and register" the transmitter code. The receiver unit memory in the
car can learn the codes of up to three different transmitters. Teaching the
transmitter code to the receiver unit is a complex process involving 15 steps,
with critical timing between certain steps. It involves pressing certain
buttons on the transmitter at certain times, and turning the ignition switch on
and off, all in specified sequences and timing. You might ask your dealer to do
this (have the receiver re-learn the transmitter code). link
Edit:
Notes:
Steps 2 through 12 must each be completed within 5 seconds.
Step 13 must be completed within 10 seconds for each remote.
Up to three remotes can be stored in the system's memory.
All remotes to be programmed must be on hand.
A non-programmed remote will work for this procedure.
Turn the ignition key to the "OFF" position to complete the programming
procedure.
1: Disarm the security system {if you have one - I didn't}
2: Turn the ignition key to the "ON" (II) position.
3: Press the "LOCK" or "UNLOCK" button on the remote control
transmitter.
4: Turn the ignition key to the "OFF" (0,I) position.
5: Turn the ignition key to the "ON" (II) position.
6: Press the "LOCK" or "UNLOCK" button on the remote control transmitter
7: Turn the ignition key to the "OFF" (0,I) position.
8: Trun the ignition key to the "ON" (II) position.
9: Press the "LOCK" or "UNLOCK" button on the remote control transmitter
10: Turn the ignition key to the "OFF" (0,I) position.
11: Turn the ignition key to the "ON" (II) position.
12: Press the "LOCK" or "UNLOCK" button on the remote control
transmitter. The power door locks will cycle to indicate that the
system is in programming mode. To terminate the programming mode
at this point, either turn the ignition key to the "OFF" position,
or leave the remote's buttons untouched for over 10 seconds.
13: Press the "LOCK" button on each remote (one at a time) that is to
be stored in memory. The power door locks will cycle to confirm
each entry. (Complete) This programming step within 10 seconds
for each remote or else the programming mode will terminate.
link
it took me 10 mins what took you 4and half hours to find out. not to be an ass but google saves lives
thanks xer0! i'll try it today. and thanks for the google tip, and sorry i just thought to try the forum first and i did search for past postings. MERRY CHRISTMAS TO ALL! :)
Edit:
Notes:
procedure.
transmitter.
link
its no problem i have fun serching on Google, just some ppl get pissed when ppl don't use t, i could careless it makes me search for it my self and learn some thing
just post again to let me know how it turned out. what pisses me off is when i help ppl out and then i don't get a repost if my idea worked or if they did some thing else.
good luck and merry x-mas
unfortunately, it didn't work according to her.. my mother tried after several hours. i did it twice to make sure. but i will try again this week. might have missed something although it's pretty straight forward instruction. too much beer i guess. will try again...
