Cluster swap question...
compuvision02
Will a gauge cluster from a Civic Type-R (EK) fit in a EH Civic? I know you can fit Integra Type-R (DC) into EH Civics, but it cuts off half the gauges and looks a little odd in terms of fitment, but will the Civic Type-R (EK) fit better?
EH/EG Cluster
EJ/EK Cluster
It will not fit? Or it will not fit pretty? Because in a way, you could say that the Integra Type-R cluster will not fit, but it does, it just has wierd gaps and such. I'm just triyng to figure out for him whether it will look cleaner then the Integra Type-R.
10k, sigh.
I don't get why everyone flames on this board. I'd rather have a tachometer that has the capability to rev that high, because it means it is much clearer. I rev to 8500RPM right now, I think when I am tuned I should be around 9000RPM and my cluster only goes to 9000RPM. It is really hard to focus when it is that far down and be accurate, even though I have a check engine light shift light now.
And it isn't like revving to 10000RPM is completely terrible. Cars do it and it works for them. Stock rev limiter for a USDM GS-R is 8200RPM and stock rev limiter for a JDM GS-R is 8500RPM and that little bit extra does a lot in a race against a USDM motor. Everyone told me 8500RPM was too high on here and I'd probably be better off shifting lower, but I believe I am making good power up there or it wouldn't be the stock limiter. Not to mention I've raced USDM GS-R EH2's and pull on them with that extra bit of time and revving.
