Clutch Help
Caspers_Civic
I just put a new clutch in my car yesterday and after removing the car from the lift I attempted to drive the car home and I am getting a really bad vibration on the passenger side of the car. the vibration gets worse at higher speed and worse when the clucth is released. Any ideals as to what the problem could be? Thanks in advance.......
pressure plate can only go on one way , maybe its not siting tight to flywheel. i assume this happened only since clutch was put in. somin is definitely not assembled properly.
You may want to check ur axcel again.. and or take the tranny off again.. and go over ur bolts.. with a torqu wrench and make sure everything is tight. I know the feeling.. of crap like that happening.. but u pretty much have to go back thru everything and do a basic trouble shoot.. even if everyone left u a comment.. its better off starting over and redueing the clutch ..
Best of luck
Mike
  • 2 weeks later...
