whatup Posted December 19, 2006 Share Posted December 19, 2006 hey everyone, I'm new to the site and would like to start off by saying hello. I have been putting some time into my 93 honda accord and have just recently replaced the ICM. I pulled the distributor off to do this and was wondering how i can set the ignition timing and what degrees it should be set to? From the searches that i have done i think that i have to disable the computer with a jumper (somewhere). Other than this, are there any other steps i have to take or can i just go with the normal timing procedure? Thank you for the help. Link to comment Share on other sites More sharing options...
..SSR.. Posted December 19, 2006 Share Posted December 19, 2006 Use a timing light and put it where it is supposed to go (dist timing). If you want to play with it more than that, you'll need an EMS. Link to comment Share on other sites More sharing options...
cranny Posted December 19, 2006 Share Posted December 19, 2006 i thought you knew everything SSR? , cross the blue 2 pin connector under the passenger side footwell. car has to be fully warmed up. FULLY. theres 4 marks on the crank pully , one by itself , 3 in a group an inch away from the one. the group of 3 , you need to mark the middle mark of the 3 with white paint , somin that will show up. with that done , hook the timing light up to the #1 plug wire(timing belt side of engine) , and to power and ground. aim the gun the the crank pully , looking straight down the pointer on the plastic timing cover. make sure when your light is flashes , the white mark you made lines perfectly up with the pointer. if it doesnt , loosen the dizzy and adjust accordingly. actually , i could be mistaken , and im not sure how far back this goes , but some of the old accords , have a little square plate that pops off where the engine meets the tranny , and the timing marks are on the flywheel , beleve it or not. and if you want to advance your timing(which by the way will do nothing for you) , other than what "know it all" seems to not know , you can advance your timing using a timing gun that has the feature. Link to comment Share on other sites More sharing options...
..SSR.. Posted December 20, 2006 Share Posted December 20, 2006 No crap sherlock. See where I said dist timing? 90-93 Accords are on the flywheel. Now go f*ck yourself. Link to comment Share on other sites More sharing options...
whatup Posted December 20, 2006 Author Share Posted December 20, 2006 Thank you guys, i really appreciate the help. Link to comment Share on other sites More sharing options...
cranny Posted December 20, 2006 Share Posted December 20, 2006 eat cock you weiner. go back to dork land. Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted December 20, 2006 Share Posted December 20, 2006 so what ssr was doing was summing up what you said, cranny, in two words. LOL Link to comment Share on other sites More sharing options...
mycarsux Posted December 22, 2006 Share Posted December 22, 2006 I found that hilarious too, pyro. Link to comment Share on other sites More sharing options...
90IntegraC1 Posted December 22, 2006 Share Posted December 22, 2006 durka durka Link to comment Share on other sites More sharing options...
tha1prince Posted June 28, 2009 Share Posted June 28, 2009 I have a timing light what should I set the settings for? Use a timing light and put it where it is supposed to go (dist timing). If you want to play with it more than that, you'll need an EMS. Link to comment Share on other sites More sharing options...
