need answer!!!
my car is in the garage right now and im installling a new head unit and speakers...got all the speakers wired up... My question is, it says hook the orange/white striped wire (positive wire) to "the cars illumination signal"
can that just be plugged into the power lead??? were is the cars illumination signal at???
That wire is for the dimming part of your headunit so your cd player will dim when you turn on the lights, like the rest of the dash lights. Just hook it to a wire that gets power when the lights are on. You should already have a wire there for that from the factory head unit. If you can't find it, buy a tester light for $5 from walmart and find the right wire.
Or, if you don't care about having the head unit dim with the rest of the dash lights, then leave that wire unhooked.
It will still light up......but you know how when you turn on your headlights, your clock get's dimmer???? Well, having that hooked up will make your cd player dim just like the clock once the headlights are turned on. You don't have to hook it up, but if you want to, your best bet would be to get a tester light to track down what wire you need. If you need more info on how to do that with the tester light, let me know.
ok, i just wont hook it up now and if its needs to be dimmed l8r ill do the tester thing u said.
i appreciate all the help :thumbsup: thanx
im going to go try it now...ill reply l8r to tell if it works...thanx
DONE...its all installed...sounds really good. thanx Hung
hookd my ipod up and all... got my ipod hook up for $4.47 at walmart.lol
one more dumb question...is it normal for the head unit to get a lil warm after like 7 minutes of play? i figured it was ok :pirate:
Tell me you used a wiring harness and didn't cut and splice everything.
well the story goes...
i was told to get a wireing harness so i did...i was thinking i would have to cut and splice but i was happy to know i didnt after getting the wireing harness...got home and took out all my speakers and the entire consol (which requires the center consol, the dash part under the steering wheel and under the passenger side dash) whick took an hour...started to read some directions and tried to fit the wireing harness in and, of course it didnt fit. CRAP...so my choices were either to... clean out all the tools and boxes etc. so i could drive the car drive into town and get a new wireing harness. or i could cut and splice everything. so i cut and splice everything...and an hour l8r it was done...but i would have much rather had the wireing harness!!! im just glad i wired everything right the first time... :laugh:
It's normal for a head unit to get pretty warm.
yeah thats wat i figured...but hey...
i went out to put the dash all back together on my car yesterday but i first decided to make sure the stereo worked...cause i would hate to put the dash together and the stereo not work, but anyway i tried to start the car and the battery was dead...i didnt want to jumpstart a deadbattery cause that would put a strain on my alternator so i just charged it all day and hopefully it will still start tomarow...
does any body know wat might cause a dead battery after a stereo install?
nah don't hook that up!
I think it's awesome when at night you turn your headlights on and your headunit makes the entire interior glow....mine glows blue, it's awesome.
mine is blue too...except for the green volume knob and the buttons but the main screen is blue.Its Freakin Sweet
but more importantly is my car going to catch on fire like 88 crxsi says cause im scared now :( lol but for real should i be worried or not?
Your battery is probably dead because your car wasn't running while doing the install. I'm sure you had an interior light on? Plus having the headunit turn on and off while installing it all would add up. I wouldn't worry about it unless it drains again.
yeah my battery wasnt dead today but i check it every once in while...
and i think the reason why the battery died was because the passenger door wasnt shut all the way and the light was on all night which would explain the completely dead battery. but i appreciate all the advice.:thumbsup:
