tegrakid06 Posted December 17, 2006 Share Posted December 17, 2006 i just recntly put a new head gasket on and my timeing belt will not stay tight i dont know y Link to comment Share on other sites More sharing options...
cranny Posted December 17, 2006 Share Posted December 17, 2006 did you tighten the tensioner? heres how you do it my man. you want the tensioner loosened only a half turn. you want no slack in between the cam wheel , and crank wheel , on the front side(rad side). than while holding the tensioner , slide the timing belt under it and around the water pump pully. than let go of tensioner. now with that complete , and of course making sure the marks are aligned properly. using a ratchet on the crank pully bolt , turn the engine counter clockwise like 4 teeth , so an inch , not even , than tighten the tensioner bolt. you should be perfect. tensioner bolt not stripped is it? cause that would be bad. Link to comment Share on other sites More sharing options...
AckNasty Posted December 18, 2006 Share Posted December 18, 2006 On my old DA (90 model) the tensioner spring was shot and would not take up the slack. You might want to check if your spring is taking up the slack. I had to push up on mine to get the slack out and then tighten the tensioner bolt. Link to comment Share on other sites More sharing options...
