What engine fits best?
Hi, i have a 1990 Acura Integra LS and i was wondering what types of engines would fit best in it with minimal fabrication (or none at all). And does it really matter what year the engine is for a swap?
B-series would be the easiest and I believe you could use the mounts from your LS engine, but not 100%. All your stuff should work, just need to take the old motor out and drop in the new. You will have to re-wire the harness for VTEC.
H-series are a tighter squeeze and you will have to change the axles, cut a hole for the shifter, and a couple other things that are not fun to do.
F-series, I do not know too much about, but you will have to change a lot of things like the H-series, I believe.
