BOOST? Posted December 17, 2006 Share Posted December 17, 2006 hey guys i was wondering if you guys could help me out. i just bought a honda civic ex with a blown motor so i figure might as well put an ls in it so im doing that but know i would like to know what type of cams,pistons,rods,and what type of suspension you guys find to be the best Link to comment Share on other sites More sharing options...
compuvision02 Posted December 17, 2006 Share Posted December 17, 2006 Well, to start, you don't have to do any of that to get the motor in. Upgrading the camshafts, pistons, rods, and suspension all have to do with what you want out of the car. Do you want to go turbo or all motor? I'm guessing turbo by your choice of engine and your username. Link to comment Share on other sites More sharing options...
BOOST? Posted December 17, 2006 Author Share Posted December 17, 2006 Well, to start, you don't have to do any of that to get the motor in. Upgrading the camshafts, pistons, rods, and suspension all have to do with what you want out of the car. Do you want to go turbo or all motor? I'm guessing turbo by your choice of engine and your username. well yeah im planing on goin turbo so wht do you suggest i do Link to comment Share on other sites More sharing options...
DTC.Monster Posted December 28, 2006 Share Posted December 28, 2006 we're doing LS Turbo to my boys car, so if you are going turbo, then you dont really have to upgrade anything unless you want to use high psi.. i mean the stock internals are suppost to be able to handle up to 14-15 psi because of its compression.. you can always go with the CP pistons and some stronger rod bolts if you're on a budget but want more power. Link to comment Share on other sites More sharing options...
airjordan223 Posted December 28, 2006 Share Posted December 28, 2006 we're doing LS Turbo to my boys car, so if you are going turbo, then you dont really have to upgrade anything unless you want to use high psi.. i mean the stock internals are suppost to be able to handle up to 14-15 psi because of its compression.. you can always go with the CP pistons and some stronger rod bolts if you're on a budget but want more power. im pretty sure stock internals cant handle that much psi, maybe half that Link to comment Share on other sites More sharing options...
Rick B. Posted December 28, 2006 Share Posted December 28, 2006 stock internals to run safely, 6-8psi. 10 is pushing it. definitely need a good tune too. dont forget that. Link to comment Share on other sites More sharing options...
..SSR.. Posted December 28, 2006 Share Posted December 28, 2006 PSI doesn't mean anything. What will you be using the car for? Link to comment Share on other sites More sharing options...
