Light weight Solutions
Jdmbb601
Posted
Hey i know that the bb6 prelude is a pretty heavy car considering it is a coupe but are there any easy solutions to cuuting the weight?
Posted
are you looking to autocross this car? if you are, the back seats and all the rear carpet, the passenger seat, basically everything except for the drivers seat. if you still want it for a DD, then ac and power steering might help a little, but not muc
Posted
CF Hood
CF Hatch
CF Fenders
Racing Seats
Gut Interior
Aftermarket Lightweight wheels
Sun Roof Delete
etc...
Posted
I have done some weight reduction on mine, stripped trunk and removed spare, Seibon CF hood and trunk, removed AC
Posted
Remove the sound deadening material under the carpet and in the trunk.
Remove the tar from the fender wells and under the chassis.
Remove PS, AC, heater core, heater ducts, radio/speakers.
Racing seats (real racing seats)
remove airbags
remove unnecessary wires
lexan windows
composite body panels
titanium rods
flywheel
header
headwork
roller cams
clutch
radiator
light wheels
acid dip then stich weld the chassis (removes ~15% of the weight from the chassis)
etc.
Posted
love it, wish the rims were gunmetal to go with the CF hood, but they still look great nontheless.
Posted
What is this stitch weld you speak of.....?
I know what it is......its a technique in welding to reduce heat warp..... how may I ask does this drop 15% of the weight?
Posted
The acid dip dissolves some of the metal of the chassis. Also dissolves all glue, tar, etc on the chassis. 15% of the bare chassis weight, not the gross chassis weight.
  • 1 month later...
Posted
Sounds expensive. How much would that set you back?
Posted
Also buying some Bride seats soon so that will help also
good god man.
bride = high (but FTMFW!)
