Phonetech Posted December 10, 2006 Share Posted December 10, 2006 I have a 95 DX Coupe in which we installed a JDM D15B and an EX ECU. It also has headers, cold air intake, adn a cat-back system. The check engine light used to come on every time the V-tech engaged. Now it is on just after starting the car, and does not go off. Since it resets every time the car is shut off, I am not sure if a shop can retrieve the code. Any one have any ideas what might be causing this. The car runs great and gets excellent milage, so whatever it is, it is not affecting the performance of the motor. Link to comment Share on other sites More sharing options...
Kastigir Posted December 10, 2006 Share Posted December 10, 2006 When a car throws a CEL, a code is stored in memory until removed. If you're not noticing any major performance issues, probably something minor like a TPS. Link to comment Share on other sites More sharing options...
willthiswork89 Posted December 10, 2006 Share Posted December 10, 2006 on most hondas there is a little blue connector that you can jump, and it will flash a code to you through the CEL, not sure on the name of it but ide look into it if i were you, Link to comment Share on other sites More sharing options...
Hatch92 Posted December 10, 2006 Share Posted December 10, 2006 I have a 95 DX Coupe in which we installed a JDM D15B and an EX ECU. It also has headers, cold air intake, adn a cat-back system. The check engine light used to come on every time the V-tech engaged. Now it is on just after starting the car, and does not go off. Since it resets every time the car is shut off, I am not sure if a shop can retrieve the code. Any one have any ideas what might be causing this. The car runs great and gets excellent milage, so whatever it is, it is not affecting the performance of the motor. 1. you only have 1 header 2. it's vtec not V-tech 3. take it to a garage and let them figure out the code. Link to comment Share on other sites More sharing options...
