turbo_d15b Posted December 7, 2006 Share Posted December 7, 2006 so my heat doesn't work...well it does, but it only works now and then...the top hose to the radiator is cool and the bottom hose is also cool to the touch?...could this be the problem of the heat not working properly? Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted December 8, 2006 Share Posted December 8, 2006 You might be out of heater fluid. Link to comment Share on other sites More sharing options...
Hondawill Posted December 8, 2006 Share Posted December 8, 2006 put a thermostat in it. Sounds like it is sticking. Link to comment Share on other sites More sharing options...
cranny Posted December 8, 2006 Share Posted December 8, 2006 sounds like its freeflow to me , lol , if its that cold. Link to comment Share on other sites More sharing options...
Chubs Posted December 8, 2006 Share Posted December 8, 2006 You may need a new heater core. Link to comment Share on other sites More sharing options...
cranny Posted December 8, 2006 Share Posted December 8, 2006 not if his rad hoses are cold when car is running for a while. Link to comment Share on other sites More sharing options...
boostedb16 Posted December 9, 2006 Share Posted December 9, 2006 After you let the car warm up...say run it at about 2000 RPMS for 5 minutes after cranking does the coolant temputure look like it's about to over heat? Also if the radiator hoses are still cold after this and the car isn't overheating then feel the heater hoses. Two twin hose at the back of the engine bay going through the firewall. If the radiator hosess still aren't hot but the car isn't overheating you need a thermostat. If the car is overheating you need a water pump. If the radiator and heater hoses are both hot you need a heater core. Link to comment Share on other sites More sharing options...
turbo_d15b Posted December 10, 2006 Author Share Posted December 10, 2006 how much does a new heater core cost? Link to comment Share on other sites More sharing options...
Chubs Posted December 10, 2006 Share Posted December 10, 2006 Im guessing maybe a 100 bucks ? Alls it is is a miniture radiator, they are easy as hell to replace also just remove your glove box it is located right behind that. Link to comment Share on other sites More sharing options...
cranny Posted December 12, 2006 Share Posted December 12, 2006 dude if your hoses are cold after running the engine you dont need a heater core. its prolly thermostat. if your hoses are under pressure or hard when engine is running , it could be a plugged rad. if the car has no heat inside , but is overheating on the gauge , its thermostat stuck shut. if the car wont heat up , generally its a thermostat stuck open. if the car is overheating after putting a new thermo in and no other prolems found , than id say waterpump. Link to comment Share on other sites More sharing options...
turbo_d15b Posted December 12, 2006 Author Share Posted December 12, 2006 see now the heat seems to work fine...the temp gauge is right in the middle...but when i drive the car...the temp gauge drops back down until it hits idle again? Link to comment Share on other sites More sharing options...
cranny Posted December 12, 2006 Share Posted December 12, 2006 your thermostat is stuck open. Link to comment Share on other sites More sharing options...
turbo_d15b Posted December 14, 2006 Author Share Posted December 14, 2006 so i guess i gotta get a new thermostat then? Link to comment Share on other sites More sharing options...
