noender Posted December 3, 2006 Share Posted December 3, 2006 hey guys last night when i was driving my civic the speed o meter lights went out, the next day i check the fuses and the intrument light fuse was burn out so i change it and when i turn on the head lights i can hear it burn out, i tried it like 3 times and the same thing happens Link to comment Share on other sites More sharing options...
XScarAudio Posted December 4, 2006 Share Posted December 4, 2006 something in the switch must be grounding out....make sure all wires are connected well behind your dimmer switch if you've ever taken off your dashboard.... then, check your headlight relay...I don't remember where that one is, but check behind the fuse box. Link to comment Share on other sites More sharing options...
noender Posted December 5, 2006 Author Share Posted December 5, 2006 i manage to fix the problem by puting tape on the stereo wires, since it got stolen all the wire were loose Link to comment Share on other sites More sharing options...
