how easy is it to install injectors?
take couple 10mm bolts off that hold the fuel rail down. disconnect the injector plugs. some just clip on , older ones have a metal clip. lift rail off injectors , sometimes they stay on rail , sometimes they stay in engine. once rail is off , they pull right out. little o rings that seal them watch for them.
They should already have the o-rings. They are saying to watch out for them as they sometimes slip off the injector and remain in the rail or injector bung in the intake. Spray a little WD-40 on the ends when you put the new ones in to help the o-rings slide into place properly. Have a mechanic's pick or a set of small electricians needle nose pliers handy just in case you have to retrieve an o-ring.
