KOBAYASHI Posted November 21, 2006 Share Posted November 21, 2006 original si motor in my c.r.x has selective starting, sometimes it wont start and sometimes it does ....! is it the coil and how do i test it ..? with a volt reader and how or test light... Link to comment Share on other sites More sharing options...
cranny Posted November 22, 2006 Share Posted November 22, 2006 could be a coil. could be a few things. Link to comment Share on other sites More sharing options...
Kegger Posted November 22, 2006 Share Posted November 22, 2006 Does it turn over? If it does it's prolly ur fuel pump not pushin gas. Mine had the same problem until I replaced the fuel pump. Edit: Si's have an internal coil so if thats it you need a new distributor. Link to comment Share on other sites More sharing options...
cranny Posted November 22, 2006 Share Posted November 22, 2006 no i think you can just put a coil in them. Link to comment Share on other sites More sharing options...
marcw842 Posted November 22, 2006 Share Posted November 22, 2006 are you sue it isn't your starter? Link to comment Share on other sites More sharing options...
Kastigir Posted November 22, 2006 Share Posted November 22, 2006 Selective starting? Main Fuel Relay. 1st Gen Rexs have external coil, 2nd gens are internal. Link to comment Share on other sites More sharing options...
redcoats1976 Posted November 22, 2006 Share Posted November 22, 2006 i have that too...if its the weekend i can jump right up,if i have to work it takes longer to get out of bed Link to comment Share on other sites More sharing options...
KOBAYASHI Posted November 23, 2006 Author Share Posted November 23, 2006 it has done this numerious of times it just wont start .. i pulled the starter and hot wired it to the battery and it still worked just fine ... so yesterday when i got off of work it pulled that shyt on me again .. i was thinking that if i parked it on a hill i could jump start it ,which i attempted to do and no dice, so i smoked a fatty and then the shyt turned over .. wtf wrong with my shyt...? my homie said prolly the coil...!i can hear my fuelpump working being that my car is gutted in the rear...? Link to comment Share on other sites More sharing options...
KOBAYASHI Posted November 23, 2006 Author Share Posted November 23, 2006 another question does an obd1 coil fit in a obd0 i know the distributor isnt compatable but what about the internals in the distributor just the coil that is...? Link to comment Share on other sites More sharing options...
Kastigir Posted November 23, 2006 Share Posted November 23, 2006 Trust me, it's the Main Relay. Link to comment Share on other sites More sharing options...
IL3GL'88 Posted November 24, 2006 Share Posted November 24, 2006 Trust me, it's the Main Relay. thats what i would think too. it happens a lot to hondas. happened to mine too. but if the main fuel relay wasnt working then youre fuel pump wouldnt do anything either. and you siad that you could hear it in the back so if thats really the case then i dont think its your relay. Link to comment Share on other sites More sharing options...
Kastigir Posted November 24, 2006 Share Posted November 24, 2006 When relays go, for some reason the fuel pump still makes noise...just doesn't pump fuel. Link to comment Share on other sites More sharing options...
KOBAYASHI Posted November 25, 2006 Author Share Posted November 25, 2006 let me see ill let you know asapif its the main relay............ fuk i hope it is , tired of praying for my ryde will to start.......... Link to comment Share on other sites More sharing options...
IL3GL'88 Posted November 25, 2006 Share Posted November 25, 2006 i was so happy when i finally figured out it was the relay. it was such an easy ass fix. Link to comment Share on other sites More sharing options...
KOBAYASHI Posted November 26, 2006 Author Share Posted November 26, 2006 i need to see if im getting fuel first ........ before hitiing up the main dont yah think...? "asking " .....................and will a e.g main wok for my crx Link to comment Share on other sites More sharing options...
IL3GL'88 Posted November 26, 2006 Share Posted November 26, 2006 i need to see if im getting fuel first ........ before hitiing up the main dont yah think...? "asking " .....................and will a e.g main wok for my crx well yah u should do that first but that shouldnt take too long. Link to comment Share on other sites More sharing options...
Kastigir Posted November 26, 2006 Share Posted November 26, 2006 i need to see if im getting fuel first ........ before hitiing up the main dont yah think...? "asking " .....................and will a e.g main wok for my crx If you're not getting fuel, then it is your Main Relay. Once you've pulled the bolt out of the fuel filter, and primed the car, try tapping on the relay, if fuel starts flowing, it's definitely the relay. Also be careful, I picked up a brand new one from the dealer, and had to tap it to work, so keep your receipts. Go buy the right relay, they're not that expensive. It most likely will work, but why take chances? Link to comment Share on other sites More sharing options...
KOBAYASHI Posted November 26, 2006 Author Share Posted November 26, 2006 what do you mean by tap it...? i just purchased a brand new main relay from ebay...wont be here in hawaii for about 9 days...! Link to comment Share on other sites More sharing options...
Kastigir Posted November 26, 2006 Share Posted November 26, 2006 Turn the key, hear the fuel pump, if there's no fuel flowing, tap the relay. If fuel begins flowing then it's *definitely* the relay. Kind of like if a starter is going out, you can get it to work by tapping it. Link to comment Share on other sites More sharing options...
IL3GL'88 Posted November 26, 2006 Share Posted November 26, 2006 he meens actually tap it, u know like with ur fingers. *taptap* Link to comment Share on other sites More sharing options...
KOBAYASHI Posted November 26, 2006 Author Share Posted November 26, 2006 got yah Link to comment Share on other sites More sharing options...
Kastigir Posted November 28, 2006 Share Posted November 28, 2006 Fingers alone won't do it. Grab a hammer or wrench. Link to comment Share on other sites More sharing options...
KOBAYASHI Posted November 29, 2006 Author Share Posted November 29, 2006 it worked it was the relay , the shyt didnt want to start so i yanked out my relay and slaped that shyt and poof walah it worked big ups on the info..................:thumbsup: Link to comment Share on other sites More sharing options...
Kastigir Posted November 29, 2006 Share Posted November 29, 2006 After having 2 Hondas, both with relay failure, I know these things. Plus, it's an *extremely* common failure. Link to comment Share on other sites More sharing options...
