{TeM}_{JeN_o_SiD} Posted November 21, 2006 Share Posted November 21, 2006 hello i have a 91 civic si with a 97 d16y8 motor and the problem is that i put my orignal harness and everything is completely plug in but the car wont start it wont crank over and i get no reaction from anything. someone please help me ??>_< Link to comment Share on other sites More sharing options...
xalexjx@yahoo.com Posted November 21, 2006 Share Posted November 21, 2006 did you use the obd1 to obdII conversion harness? Link to comment Share on other sites More sharing options...
adamEj6 Posted November 21, 2006 Share Posted November 21, 2006 check all your fuses and common sense things Link to comment Share on other sites More sharing options...
civic_from_hell Posted November 21, 2006 Share Posted November 21, 2006 i had a friend with the same problem check the distributor connector (ecu to dist.) commonly missed. Link to comment Share on other sites More sharing options...
{TeM}_{JeN_o_SiD} Posted November 22, 2006 Author Share Posted November 22, 2006 Thanks for the comments but i checked everything and all i get is no start not even a crank over but i wish i could just go kazamm and "boom" it will start up but i think it is a my igntion but plz just keeping more things it might be and no i didnt use the obd1-obd2 harness i saw a forum and it said that i could run my orignal harness a dist. and ecu and it would work but crap wont wirk lol Link to comment Share on other sites More sharing options...
cranny Posted November 22, 2006 Share Posted November 22, 2006 you cant use a obd0 harness and ecu to run an obd2a engine. Link to comment Share on other sites More sharing options...
{TeM}_{JeN_o_SiD} Posted November 22, 2006 Author Share Posted November 22, 2006 why cant you i heard and i read on the forum you can all you have to is get a vtec controller Link to comment Share on other sites More sharing options...
Kegger Posted November 22, 2006 Share Posted November 22, 2006 Youe can't because the ECU in the car right now won't recognize your dizzy. No matter what you do it won't work. You need the whole harness, distributor, and ECU for it to even think about starting. Link to comment Share on other sites More sharing options...
cranny Posted November 22, 2006 Share Posted November 22, 2006 you could prolly change the pinout of the dizzy so the wires were run to thier proper places to the ecu , but its still not the right fuel map for that car. even if you get that ecu to run that engine , it will never run good. Link to comment Share on other sites More sharing options...
STYLESABU Posted November 27, 2006 Share Posted November 27, 2006 you will need the right controler(ecm) for that engine.but your engine should still crank.that signal comes from the ignition switch through neutral saftey or clutch switch to starter.i went through 2 ign switches in my 91 civic in 175000 miles. Link to comment Share on other sites More sharing options...
cranny Posted November 27, 2006 Share Posted November 27, 2006 if i had the car in front of me , i could prolly get it running , but its hard without seeing. does the car have power when you turn the key to on position? does the engine light come on for 3 seconds than go out? Link to comment Share on other sites More sharing options...
KOBAYASHI Posted November 28, 2006 Share Posted November 28, 2006 "ground" by the thermostat is it grounded it wont do exactly what your talkin about if that shyt aint bolted and grounded............ Link to comment Share on other sites More sharing options...
