lsvtec90teg Posted November 21, 2006 Share Posted November 21, 2006 aight i got a ls vtec teg i wanna swap the auto out and make it 5 spd what do i need and how big of a bit** is it?????????? Link to comment Share on other sites More sharing options...
90IntegraC1 Posted November 21, 2006 Share Posted November 21, 2006 i did it....it's a bitch. what you need: MT MT axle's MT Mid-Shaft Clutch PP Flywheel Flywheel Bolts PP Bolts Clutch Cable (i swapped in a cable trans) Pedal Assembly Shift Linkage Shifter MT Mounts Clutch Cable Brackets (3, one on trans, 2 on Valve Cover) 3 MT Starter Bolts Reverse Switch MT ECU ( I'm running the auto cause it's OBD-0) MT Cluster MT Intake Manifold Intake Manifold Gasket MT IACV Get rid of AT Vacuum Lines You'll need to shim the Passenger Side motor mount (raise it so the engine is level) I'm probably missing things...but there's the general list.... Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted November 21, 2006 Share Posted November 21, 2006 They do make auto to manual conversion mounts so you dont have to shim it, I will be getting one soon for my del Sol hopefully. Link to comment Share on other sites More sharing options...
90IntegraC1 Posted November 21, 2006 Share Posted November 21, 2006 they do?? where could i get one? Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted November 22, 2006 Share Posted November 22, 2006 Here ya go Dan. Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted December 3, 2006 Share Posted December 3, 2006 Did you look at it, Dan? Link to comment Share on other sites More sharing options...
90IntegraC1 Posted December 3, 2006 Share Posted December 3, 2006 damn, not a bad price at all.... bookmarked, i'll be purchasing that asap. Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted December 3, 2006 Share Posted December 3, 2006 I think my parents are buying me one for Christmas. Its a lot cheaper at inlinefour.com. Link to comment Share on other sites More sharing options...
