lsvtec90teg Posted November 20, 2006 Share Posted November 20, 2006 aight i bought this 90 integra gs with a gsr head on a ls block the oil line is tapped and ran and everything is pretty much done i just need to run the vtech pigtail thing and i need to know what to do with the vacuum lines and mainly everything else like the sensors and stuff can some one give me an idea on where to start???????thanks Link to comment Share on other sites More sharing options...
cranny Posted November 20, 2006 Share Posted November 20, 2006 a vtec pigtail thing? lol. take some pics of under your hood and that will help more. Link to comment Share on other sites More sharing options...
lsvtec90teg Posted November 21, 2006 Author Share Posted November 21, 2006 a vtec pigtail thing? lol. take some pics of under your hood and that will help more. what u want me to do with the pics??????????? Link to comment Share on other sites More sharing options...
cranny Posted November 21, 2006 Share Posted November 21, 2006 upload them to photobucket and post em here , lol. Link to comment Share on other sites More sharing options...
lsvtec90teg Posted November 21, 2006 Author Share Posted November 21, 2006 upload them to photobucket and post em here , lol. well do i need a special timin belt for the gsr head bein on the ls block or willl it work with the stock one??? and are the sensors and vac lines ran the same or what ill take pics tommorow and put them up but do u know what im talkin bout and the vtec pigtail does it plug into the ecu and the go to the vtec solenoid or wheres it go im new to hondas im an ex-dsm guy Link to comment Share on other sites More sharing options...
90Tegtyper Posted November 21, 2006 Share Posted November 21, 2006 well do i need a special timin belt for the gsr head bein on the ls block or willl it work with the stock one??? and are the sensors and vac lines ran the same or what ill take pics tommorow and put them up but do u know what im talkin bout and the vtec pigtail does it plug into the ecu and the go to the vtec solenoid or wheres it go im new to hondas im an ex-dsm guy PIN LOCATIONS FOR WIRING OBD-0 ECU VTEC Pressure Switch pin B5 VEC Solenoid pin A8 Knock Sensor pin B19 Second O2 Sensor pin C8 OBD-I ECU VTEC Pressure Switch pin D6 VEC Solenoid pin A4 Knock Sensor pin D3 Intake Air Bypass Valve (GS-R only) pin A17 Evaporative Purge Solenoid Valve pin A20 OBD-II 1996-1998 ECU VTEC Pressure Switch pin C15 VTEC Solenoid pin A8 Knock Sensor pin D6 Intake Air Bypass Valve (GS-R only) pin A26 OBD-II 1999-2001 ECU VTEC Pressure Switch pin C10 VTEC Solenoid pin B12 Knock Sensor in C3 Intake Air Bypass Valve (GS-R only) pin B16 you people forgot to even ask what obd it is so you could be wrong Link to comment Share on other sites More sharing options...
cranny Posted November 21, 2006 Share Posted November 21, 2006 you people forgot to even ask what obd it is so you could be wrong what you mean you could be wrong , only me and you have posted and neither of us have suggested anything yet , haha , jesus man. i got all the pinouts as well dude , but we still need to know what hes talking about pigtail thing , lol. you need a timing belt off a gsr im pretty sure. vtec heads are taller. and LS blocks are taller than C blocks. maybe it evens out im not sure. youl know when you go to put it on. tensioner gives you a little play. Link to comment Share on other sites More sharing options...
