Kicksome123 Posted November 18, 2006 Share Posted November 18, 2006 When I get on my car pretty hard its pretty hard to shift into 2nd. Is this normal or what??? Cause if I dont pull hard enough it gets stuck in neutral and just over revs... Its embarassing.. Link to comment Share on other sites More sharing options...
coolcat467 Posted November 18, 2006 Share Posted November 18, 2006 Are you holding the shifter to the left when you try to shift? Link to comment Share on other sites More sharing options...
Kicksome123 Posted November 18, 2006 Author Share Posted November 18, 2006 Are you holding the shifter to the left when you try to shift? Yep, im not that horrible at driving a stick yo.. lol. Its just hard shifting into second and only that gear Link to comment Share on other sites More sharing options...
coolcat467 Posted November 18, 2006 Share Posted November 18, 2006 Yeah, I know, I just had to ask. I honestly have no idea why it is happening though. Sorry man Link to comment Share on other sites More sharing options...
Kicksome123 Posted November 18, 2006 Author Share Posted November 18, 2006 Yeah, I know, I just had to ask. I honestly have no idea why it is happening though. Sorry man Thanks for trying man =P Anyone else have any ideas though??? Link to comment Share on other sites More sharing options...
Humphries Posted November 18, 2006 Share Posted November 18, 2006 shifter bushing might need changing.. or your 2nd gear synchro is going out. Link to comment Share on other sites More sharing options...
coolcat467 Posted November 18, 2006 Share Posted November 18, 2006 Yeah I knew that. I just wanted to see if EBP_EM1 knew that. j/k man Link to comment Share on other sites More sharing options...
Kicksome123 Posted November 18, 2006 Author Share Posted November 18, 2006 How expensive of a fix from the mechanic is that, or could I do it myself? Link to comment Share on other sites More sharing options...
cranny Posted November 18, 2006 Share Posted November 18, 2006 if its tranny internals and you havent had one apart , i wouoldnt recommend it. it could just be your clutch getting old. could be your not holding it to the floor long enough or all the way to the floor. Link to comment Share on other sites More sharing options...
Kicksome123 Posted November 18, 2006 Author Share Posted November 18, 2006 if its tranny internals and you havent had one apart , i wouoldnt recommend it. it could just be your clutch getting old. could be your not holding it to the floor long enough or all the way to the floor. is that a yes to a mechanic or no? I have never took a tranny apart and I shift into second just as fast as any other gear so I dunno... Dont really think its my clutch though but if I pull it back hard enough it will get into 2nd you just gotta pull hard. On my dads truck in the winter he has to put this certain brake fluid that has some clutch enhancer that you can use. Would you guys think this would help??? Link to comment Share on other sites More sharing options...
Rick B. Posted November 18, 2006 Share Posted November 18, 2006 try holding the clutch in a little bit longer. does it grind at all? Link to comment Share on other sites More sharing options...
Kicksome123 Posted November 18, 2006 Author Share Posted November 18, 2006 try holding the clutch in a little bit longer. does it grind at all? Yea I can hear it grind if I dont pull hard enough yes... Link to comment Share on other sites More sharing options...
Nancy Posted November 18, 2006 Share Posted November 18, 2006 synchro is going bad, it happened to my third gear in my gsr and in my itr tranny. had it fixed for about 300. Link to comment Share on other sites More sharing options...
Kicksome123 Posted November 18, 2006 Author Share Posted November 18, 2006 synchro is going bad, it happened to my third gear in my gsr and in my itr tranny. had it fixed for about 300. Did you do it or did a mechanic? Link to comment Share on other sites More sharing options...
Nancy Posted November 18, 2006 Share Posted November 18, 2006 i dont mess with trannys, had one of my friends who is a mechanic do it. you know, if you do decide to do that, have them check everything in there while its all open and you might even want to get an lsd. Link to comment Share on other sites More sharing options...
Kicksome123 Posted November 18, 2006 Author Share Posted November 18, 2006 i dont mess with trannys, had one of my friends who is a mechanic do it. you know, if you do decide to do that, have them check everything in there while its all open and you might even want to get an lsd. I have been meaning to ask yall what a lsd is... and what it does. Link to comment Share on other sites More sharing options...
Nancy Posted November 18, 2006 Share Posted November 18, 2006 lsd= limited slip differential as opposed to an open one. with an lsd both your front wheels will be working rather than one. better for take off and handling. so if you did a nice burn out like 97civictuner youll leave two tire marks. edit- all itr trannys come with a stock lsd Link to comment Share on other sites More sharing options...
Kicksome123 Posted November 18, 2006 Author Share Posted November 18, 2006 lsd= limited slip differential as opposed to an open one. with an lsd both your front wheels will be working rather than one. better for take off and handling. so if you did a nice burn out like 97civictuner youll leave two tire marks. edit- all itr trannys come with a stock lsd Ohh okay, they expensive??? Link to comment Share on other sites More sharing options...
Nancy Posted November 19, 2006 Share Posted November 19, 2006 Ohh okay, they expensive??? a used oem honda itr lsd goes for about 430-450 maybe. not sure on the other brands. but i know quaife makes really good lsd's but im sure theyre very expensive. Link to comment Share on other sites More sharing options...
Kicksome123 Posted November 19, 2006 Author Share Posted November 19, 2006 a used oem honda itr lsd goes for about 430-450 maybe. not sure on the other brands. but i know quaife makes really good lsd's but im sure theyre very expensive. 0_0 might have to wait a little while for that. Can I keep driving it like this without any other major problems happening? Link to comment Share on other sites More sharing options...
Rick B. Posted November 19, 2006 Share Posted November 19, 2006 you can keep driving it, but if you dont get it fixed, it will end up like mine. Link to comment Share on other sites More sharing options...
Kicksome123 Posted November 19, 2006 Author Share Posted November 19, 2006 you can keep driving it, but if you dont get it fixed, it will end up like mine. Well this only happens when I get on it hard, so I will have to put it off for awhile Link to comment Share on other sites More sharing options...
4doorcivic9 Posted December 6, 2006 Share Posted December 6, 2006 Well this only happens when I get on it hard, so I will have to put it off for awhile If you keep doing it to much it will get worse (the grind will) and eventually your synchronizer will go out and you wont have a gear! so try and get it fixed as soon as possible. Actually if you dont have the money to get it fixed and to keep it from tearing up to soon, you can go to any local place (autozone, oreilleys etc) and get synchro mesh. Make sure you drain your transmission all the way before putting synchro mesh in your transmission. Put at least 3 or 4 quarts of synchro mesh in your tranny and you'll tell a big difference in grind and even shifting in general Link to comment Share on other sites More sharing options...
boostedb16 Posted December 10, 2006 Share Posted December 10, 2006 Hate to tell you but it is the sycroniser from 1st to 2nd. It's not your clutch because it's not grinding going into any other gears and it's not your bushing because it's not doing it going into reverse. Try outting a quart of GM Syncromesh fluid in it. Drive it for about a week and that should help some. This is just a temporary fix however. Eventually you will have to send the transmission out to be rebuilt/ replaced. Link to comment Share on other sites More sharing options...
GsrCrx Posted December 10, 2006 Share Posted December 10, 2006 If you keep doing it to much it will get worse (the grind will) and eventually your synchronizer will go out and you wont have a gear! Hmm... I thought you didnt need syncros...Correct me if Im wrong here but without a syncro you just have to rev-match everthing...Thats what we do with my pop's abarth that I still have to take pics of.. for someone... just to save the syncros... If you downshift into second.. leave it in neutral before you put it into second for a second (haha) and give it a little gas so the rpm's go up, than try and put it into second like you normally would with the rpms falling... Again correct me if im wrong because I wouldent want to spread false info... Link to comment Share on other sites More sharing options...
