cloc007 Posted November 18, 2006 Share Posted November 18, 2006 i have 91 dx hatch and im doing a dpfi to mpfi conversion but cant find an si computer does any one know if i can use a 92-95 dx computer or a 90 -93 integ computer for a sub i also have a del so intake manifold will this pose as a problem Link to comment Share on other sites More sharing options...
cranny Posted November 18, 2006 Share Posted November 18, 2006 than youd have to obd convert your car. all you need to do is change a few wires for the extra 2 injectors. the ecu in your car can run MPFI. here ya go my man. DPFI MPFI Pin# Wire Color Function Wire Color Function A1 Yellow 2 Aux Injector , Brown #1 Injector A2 Black 1 Main Relay/Ground , Black 1 Main Relay/Ground A3 Yellow 1 Aux Injector , Red #2 Injector A4 Black 2 Main Relay/Ground , Black 2 Main Relay/Ground A5 Red 2 Main Injector , Light Blue #3 Injector A6 Green Purge Cut Off Solenoid Valve (Coil) , Green Purge Cut Off Solenoid Valve (Coil) A7 Red 1 Main Injector , Yellow 1 #4 Injector A8 Yellow 3 Sedan LX (A/T only) A10 Red EGR Solenoid Control Valve (Coil) (A/T only) A11 Blue/Yellow EACV (Coil) , Blue/Yellow EACV (Coil) A12 Green/Black 2 Main Relay , Green/Black 2 Main Relay A13 Yellow/Black 2 Main Relay , Yellow/Black 2 Main Relay/Injector Resistor Box A14 Green/Black 1 Main Relay , Green/Black 1 Main Relay A15 Yellow/Black 1 Main Relay , Yellow/Black 1 Main Relay/Injector Resistor Box A16 Brown/Black Ground , Brown/Black Ground A17 A18 Black/Red Ground , Black/Red Ground Pin# Wire Color Function Wire Color Function B1 White/Green Hazard Fuse , White/Green Hazard Fuse B2 Orange Tandem Control Solenoid Valve , Blue 1 Fast Idle Control Solenoid Valve B3 Yellow A/C Clutch Relay , Yellow A/C Clutch Relay B4 Yellow/Green Radiator Fan Relay , Yellow/Green Radiator Fan Relay B5 White/Yellow Alternator , White/Yellow Alternator B6 Green/Orange Check Engine Warning Light , Green/Orange Check Engine Warning Light B7 Green/Orange Position Console Switch (Park, Neutral) , (A/T only) B8 Blue/Red A/C Switch , Blue/Red A/C Switch B9 B10 Orange Crank Angle Sensor B11 Green/Black A/T Shift Position Console Switch (Drive) , (A/T only) B12 White Crank Angle Sensor B13 Blue/White Main Relay , Blue/White Main Relay B14 Blue 2 To Yellow, To Alternator Blue 2 Alternator B15 White 1 Ignitor Unit White 1 Ignitor Unit B16 Yellow/Red Speed Sensor Yellow/Red Speed Sensor B17 White 2 Ignitor Unit White 2 Ignitor Unit B18 B19 Green/Red Electric Load Detector Green/Red Electric Load Detector B20 Brown Ignition Timing Adjusting Connector Brown Ignition Timing Adjusting Connector Pin# Wire Color Function Wire Color Function C1 Orange Crank Angle Sensor Blue/Green Cylinder Position Sensor C2 White 4 Crank Angle Sensor Blue/Yellow Cylinder Position Sensor C3 Orange/Blue TDC Sensor Orange/Blue TDC Sensor C4 White/Blue TDC Sensor White/Blue TDC Sensor C5 Red/Yellow TA Sensor Red/Yellow TA Sensor C6 Red/White 1 TW Sensor Red/White 1 TW Sensor C7 Red/Blue Throttle (Position) Angle Sensor (TPS) Red/Blue Throttle (Position) Angle Sensor (TPS) C8 Yellow EGR Lift Valve Sensor C9 Red/White 2 PA Sensor Red/White 2 PA Sensor C10 Green/White 3 Brake Switch Green/White 3 Brake Switch C11 White 1 MAP Sensor White 1 MAP Sensor C12 Green/White 2 EGR Lift Valve Sensor/Pa Sensor/Ignition Timing Adjusting Connector/TA Sensor/TPS Sensor/TW Sensor Green White 2 Pa Sensor/Ignition Timing Adjusting Connector/TA Sensor/TPS Sensor/TW Sensor C13 Yellow/White EGR Lift Valve Sensor/Pa Sensor/TPS Sensor Yellow/White Pa Sensor/TPS Sensor C14 Green/White 1 MAP Sensor Green/White 1 MAP Sensor C15 Yellow/Red MAP Sensor Yellow/Red MAP Sensor C16 White 3 O2 Sensor White 3 O2 Sensor Link to comment Share on other sites More sharing options...
cloc007 Posted November 18, 2006 Author Share Posted November 18, 2006 thanx but what i really wanted to know is there any other ecu i can use besides si 88-89 teg like maybey 90-91 teg Link to comment Share on other sites More sharing options...
cranny Posted November 19, 2006 Share Posted November 19, 2006 why though if yours wil work? Link to comment Share on other sites More sharing options...
cloc007 Posted November 19, 2006 Author Share Posted November 19, 2006 why though if yours wil work? so besides the four wires for the fuel injectors do i still need to run c1 and c2 for the distributer Link to comment Share on other sites More sharing options...
cranny Posted November 19, 2006 Share Posted November 19, 2006 i posted the differences right there , read them find whats different , make it so , simple as that honest to god. Link to comment Share on other sites More sharing options...
cloc007 Posted November 19, 2006 Author Share Posted November 19, 2006 i did all of this and the car just cranks and i double checked everything now do i need si ditrib and computer cause for the pm5 it does not have crank sensors at b10 and twelveB9 B10 B11 Green/Black A/T Shift Position Console Switch (Drive) B12 and thats the pm5 now th pm6 looks like thisB9 B10 Orange Crank Sensor B11 Green/Black A/T Shift Position Console Switch (Drive) B12 White Crank Sensor Inside car @ ECU Pins B10 and B12 are empty. Unused pins can be taken from B2 or B11. Some models have a wire located at B12. 1. Cut orange and white wires off at C1 and C2 and connect them to wires added at B10 and B12. Orange-B10. White-B12. Leave enough wire for next step. 2. Run wires from C1 and C2 (direct ECU connection) into the engine compartment. Label these wires for later use. 3. Cut wires at A3 and A7 leaving plenty of wire. Run these wires into the engine compartment and label them for later use. Before installing MPFI manifold TPS and EACV plugs are too short and must be extended. 1. Be sure to switch green/white and yellow/white wires on TPS Injectors and injector resistor box Connect the yellow/black wires from the two DX injector harnesses and run it to the yellow/black wire on the injector resistor box. 1. Connect the yellow wire from the DX injector to the #1 injector (brown wire). 2. Connect the red wire from the DX injector and run it to the #3 injector (blue wire). 3. Connect the A3 wire to the #2 injector (red wire). 4. Connect the A7 wire to the #4 injector (yellow wire). 5. Connect the 4 red/black wires from injector resistor box to each injector. Cylinder position sensor Connect C1 to blue/green wire on cylinder position sensor plug. 1. Connect C2 to blue/yellow wire on cylinder position sensor plug. 2. These wires are off the Si distributor so connect them there. That's it. Double check everything and start it up. Good luck! Link to comment Share on other sites More sharing options...
cranny Posted November 19, 2006 Share Posted November 19, 2006 you have an auto? Link to comment Share on other sites More sharing options...
90Tegtyper Posted November 19, 2006 Share Posted November 19, 2006 you have an auto? you cannot use the pm5 ecu for mpfi swap gotta use a si(pm6) Link to comment Share on other sites More sharing options...
cloc007 Posted November 19, 2006 Author Share Posted November 19, 2006 you have an auto? no i have a born stick shift no conversion never a female Link to comment Share on other sites More sharing options...
cloc007 Posted November 19, 2006 Author Share Posted November 19, 2006 you cannot use the pm5 ecu for mpfi swap gotta use a si(pm6) thats what i assumed i was also told i could use the 88 -89 teg ecu i know that works but first do u know where the ecu is in that year integ its not in the passenger floor or kick panel and do i have to use an si ditrib Link to comment Share on other sites More sharing options...
90Tegtyper Posted November 20, 2006 Share Posted November 20, 2006 thats what i assumed i was also told i could use the 88 -89 teg ecu i know that works but first do u know where the ecu is in that year integ its not in the passenger floor or kick panel and do i have to use an si ditrib im not sure where they are and yes you have to use the si dist because they rotate backwards the opposite way a si does or something along that idea and i do have a pm6 sitting in front of me right now... interested? Link to comment Share on other sites More sharing options...
cranny Posted November 20, 2006 Share Posted November 20, 2006 my bad , i did think you could wire a PM5 for mpfi. he could use the teg ecu , but its not the right fuel map for the engine. would run rich , idle crapty a bit prolly. sorry dude , my mistake. your best bet is getting that pm6 from teg and adding those couple extra wires to the existing harness. Link to comment Share on other sites More sharing options...
90Tegtyper Posted November 20, 2006 Share Posted November 20, 2006 my bad , i did think you could wire a PM5 for mpfi. he could use the teg ecu , but its not the right fuel map for the engine. would run rich , idle crapty a bit prolly. sorry dude , my mistake. your best bet is getting that pm6 from teg and adding those couple extra wires to the existing harness. theres actually 2 wires you have to move to other pins and then 2 other injector wires like you said but then you have to hook up the injector resistor, dpfis dont have them, and a pm6 is from a 88-91 si not teg. and no point in using the teg ecu cuz its dual cam they work on zcs i dont think on z6's though and you would have to get the corresponding dizzy. just get a PM6 ecu. and the si dizzy Link to comment Share on other sites More sharing options...
cranny Posted November 20, 2006 Share Posted November 20, 2006 yeah that difference is listed on the conversion map there. Link to comment Share on other sites More sharing options...
cloc007 Posted November 20, 2006 Author Share Posted November 20, 2006 theres actually 2 wires you have to move to other pins and then 2 other injector wires like you said but then you have to hook up the injector resistor, dpfis dont have them, and a pm6 is from a 88-91 si not teg. and no point in using the teg ecu cuz its dual cam they work on zcs i dont think on z6's though and you would have to get the corresponding dizzy. just get a PM6 ecu. and the si dizzy ok thanks and i get all of thAt but what the hell is this dizzy every one keeps refering to and do u know of anybody who has done this succefully and if u look further up u can see my wiring plans is that 100% correct Link to comment Share on other sites More sharing options...
90Tegtyper Posted November 20, 2006 Share Posted November 20, 2006 ok thanks and i get all of thAt but what the hell is this dizzy every one keeps refering to and do u know of anybody who has done this succefully and if u look further up u can see my wiring plans is that 100% correct dizzy is the distributor and yea me and a friend have done it before just look here and follow it http://effinmotorworks.com/Effin_MPFI_swap.htm Link to comment Share on other sites More sharing options...
cloc007 Posted November 20, 2006 Author Share Posted November 20, 2006 dizzy is the distributor and yea me and a friend have done it before thanks alot man so every thing works good on the one u tried?, well hopefully ill get the "dizzy" and ecu tonight u've been a big help Link to comment Share on other sites More sharing options...
90Tegtyper Posted November 20, 2006 Share Posted November 20, 2006 thanks alot man so every thing works good on the one u tried?, well hopefully ill get the "dizzy" and ecu tonight u've been a big help no problem, I have the ecu sittin here ive been tryin to get rid of it. and yea it worked but we had to go over th wires a bunch of time lol and when you count the pin in the harness at the ecu make sure you do it like it shows on that site Link to comment Share on other sites More sharing options...
cloc007 Posted November 21, 2006 Author Share Posted November 21, 2006 no problem, I have the ecu sittin here ive been tryin to get rid of it. and yea it worked but we had to go over th wires a bunch of time lol and when you count the pin in the harness at the ecu make sure you do it like it shows on that site thanx how much do u want for it or what if a trade is possible cause i get things i would get that but an si is hard to find Link to comment Share on other sites More sharing options...
cloc007 Posted December 30, 2006 Author Share Posted December 30, 2006 no problem, I have the ecu sittin here ive been tryin to get rid of it. and yea it worked but we had to go over th wires a bunch of time lol and when you count the pin in the harness at the ecu make sure you do it like it shows on that site i havent been here in a while but since october i did a bit of a franky i have and obd1 dizzy on the 91 mpfi conversion and wired the dizzy to match it all the wires are correct including the dizzy before i fnish with the two wire ci and c2 will this still turn over Link to comment Share on other sites More sharing options...
