ilovevtecs Posted November 15, 2006 Share Posted November 15, 2006 im experiecing weird idiling when im at a complete stop. rpms rise and drop consistenly. could it be the distributor maybe? Link to comment Share on other sites More sharing options...
TS John Posted November 15, 2006 Share Posted November 15, 2006 Generally that's something with your O2 sensor or vaccum leaks. Generally that's something with your O2 sensor or vaccum leaks. Link to comment Share on other sites More sharing options...
xalexjx@yahoo.com Posted November 15, 2006 Share Posted November 15, 2006 prolly a vacuum leak or ivafc, if you want to hide it just turn your idle up slightly Link to comment Share on other sites More sharing options...
90Tegtyper Posted November 16, 2006 Share Posted November 16, 2006 new thermostat and adjust idle down after, hows the temp? mostly always cold? Link to comment Share on other sites More sharing options...
cranny Posted November 16, 2006 Share Posted November 16, 2006 new thermostat and adjust idle down after, hows the temp? mostly always cold? are you joking me? please dont advise people to do things that are wrong. never adjust the idle on a fuel injected car. you need to clean your IACV. reseal the plastic screw maybe. Link to comment Share on other sites More sharing options...
mycarsux Posted November 16, 2006 Share Posted November 16, 2006 Yeah its either a dirty IACV or a vacuum leak. Clean the IACV, and check/repair vacuum tubes. Link to comment Share on other sites More sharing options...
90Tegtyper Posted November 17, 2006 Share Posted November 17, 2006 are you joking me? please dont advise people to do things that are wrong. never adjust the idle on a fuel injected car. you need to clean your IACV. reseal the plastic screw maybe. first of all - when it fluxuates it more than likely pushed the idle screw out a lil bit secondly - the piece with the white plastic screw is actually called the FITV ( FAST IDLE THERMO VALVE ) third - when i said adjust the idle down i said after he changes the thermostat and if the idles not fixed then tune it down yes it could also be the FITV but in that case if it pushed out that means theres possibly a cooling problem i.e thermostat. if not either of those check vaacum lines trace where they are or possibly need a new IM gasket. Link to comment Share on other sites More sharing options...
TS John Posted November 17, 2006 Share Posted November 17, 2006 How helpful would it have been to tell him to push in his Fast Idle Thermo Valve? Cranny is a car repair man of the people. Link to comment Share on other sites More sharing options...
cranny Posted November 17, 2006 Share Posted November 17, 2006 first of all - when it fluxuates it more than likely pushed the idle screw out a lil bitsecondly - the piece with the white plastic screw is actually called the FITV ( FAST IDLE THERMO VALVE ) third - when i said adjust the idle down i said after he changes the thermostat and if the idles not fixed then tune it down yes it could also be the FITV but in that case if it pushed out that means theres possibly a cooling problem i.e thermostat. if not either of those check vaacum lines trace where they are or possibly need a new IM gasket. anyways im not gonna argue with you , what do i know. adjust the idle than what do i give a fuk. Link to comment Share on other sites More sharing options...
90Tegtyper Posted November 17, 2006 Share Posted November 17, 2006 anyways im not gonna argue with you , what do i know. adjust the idle than what do i give a fuk. dont mean to argue either i just know what im talking about with this problem Link to comment Share on other sites More sharing options...
cranny Posted November 17, 2006 Share Posted November 17, 2006 hahaha , apparently as far as you know. given the fact your telling him to adjust his idle screw tells me you dont know crap. Link to comment Share on other sites More sharing options...
90Tegtyper Posted November 17, 2006 Share Posted November 17, 2006 hahaha , apparently as far as you know. given the fact your telling him to adjust his idle screw tells me you dont know crap. im just goin to say OK and leave it at that. no need for a fight. Link to comment Share on other sites More sharing options...
KOBAYASHI Posted November 20, 2006 Share Posted November 20, 2006 "Intake gasket " Link to comment Share on other sites More sharing options...
90Tegtyper Posted November 20, 2006 Share Posted November 20, 2006 How helpful would it have been to tell him to push in his Fast Idle Thermo Valve? Cranny is a car repair man of the people. ok but that dosent mean that i dont know what im talking about when infact i do Link to comment Share on other sites More sharing options...
Hatch92 Posted November 20, 2006 Share Posted November 20, 2006 i'm gonna have to say IACV or a vaccum line Link to comment Share on other sites More sharing options...
cranny Posted November 20, 2006 Share Posted November 20, 2006 noones saying that teg , just most likely this is the cause of that prolem. Link to comment Share on other sites More sharing options...
90Tegtyper Posted November 20, 2006 Share Posted November 20, 2006 noones saying that teg , just most likely this is the cause of that prolem. alright alright wheres the love i hate the bickering on this site lol Link to comment Share on other sites More sharing options...
cranny Posted November 20, 2006 Share Posted November 20, 2006 we love you man , lol . Link to comment Share on other sites More sharing options...
