FloridaUFGator Posted November 9, 2006 Share Posted November 9, 2006 I consistently have delayed acceleration on my 2004 Accord EX-L. I usually see it when slowing down to almost a stop and then starting again. I've also seen it when coasting and then pressing the gas pedal. I push the gas and it doesn't respond for a good 1+ seconds. Has anyone else seen this? Do I have a transmission problem? Side Note: It seems to not happen as much when in overdrive (D3). Link to comment Share on other sites More sharing options...
mycarsux Posted November 9, 2006 Share Posted November 9, 2006 You have broken motor mounts. Congratulations. Did you like hit any huge bumps recently? Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted November 9, 2006 Share Posted November 9, 2006 ^^^ um where did that even come from? that would be the last thing i'd suspect it would be...... Link to comment Share on other sites More sharing options...
cranny Posted November 9, 2006 Share Posted November 9, 2006 might be as simple as a dirty filter , be it air or fuel. PCV valve , could be anything dude. Link to comment Share on other sites More sharing options...
90IntegraC1 Posted November 9, 2006 Share Posted November 9, 2006 broken motor mounts?? wtf.... Link to comment Share on other sites More sharing options...
FloridaUFGator Posted November 9, 2006 Author Share Posted November 9, 2006 might be as simple as a dirty filter , be it air or fuel. PCV valve , could be anything dude. Why doesn't it happen on over-drive then? Link to comment Share on other sites More sharing options...
mycarsux Posted November 9, 2006 Share Posted November 9, 2006 I swear that sounds exactly what happened to my bro's camry. He broke 3 our of 4 motor mounts and when he pressed the acclerator it would go slow and then kick in and jerk forward. See where I'm coming from?? EDIT: It could even be a vacuum leak. The reason why it doesn't have any affect in overdrive is because there's so much air going into the engine that a leak has almost no effect at WOT. Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted November 9, 2006 Share Posted November 9, 2006 Bad torque convertor? Link to comment Share on other sites More sharing options...
Dabbs93Accord Posted November 10, 2006 Share Posted November 10, 2006 Your Torque converter could be bad. Link to comment Share on other sites More sharing options...
cranny Posted November 11, 2006 Share Posted November 11, 2006 id say its a solenoid before torque converter. Link to comment Share on other sites More sharing options...
