nightshift customs Posted November 8, 2006 Share Posted November 8, 2006 im not to bright when it comes to 4 cylinders but my buddys gotta a 1991 crx and we are tubochargin it and the head is gettin redone with stainless valves and im gettin 8-1 pistons im gonna run 8 psi what do i buy? Link to comment Share on other sites More sharing options...
mocker75 Posted November 8, 2006 Share Posted November 8, 2006 What kind of engine? Link to comment Share on other sites More sharing options...
airjordan223 Posted November 8, 2006 Share Posted November 8, 2006 go here Link to comment Share on other sites More sharing options...
Hatch92 Posted November 8, 2006 Share Posted November 8, 2006 need to know what engine u have then everyone can go from there. Link to comment Share on other sites More sharing options...
nightshift customs Posted November 9, 2006 Author Share Posted November 9, 2006 What kind of engine? its a 1.6L d16a6 SI Link to comment Share on other sites More sharing options...
nightshift customs Posted November 9, 2006 Author Share Posted November 9, 2006 What kind of engine? 1.6L d16a6 SI Link to comment Share on other sites More sharing options...
Hatch92 Posted November 9, 2006 Share Posted November 9, 2006 1.6L d16a6 SI now do you want to make you own kit or buy 1 already done by a company? Link to comment Share on other sites More sharing options...
nightshift customs Posted November 9, 2006 Author Share Posted November 9, 2006 now do you want to make you own kit or buy 1 already done by a company? well like i said im not to mechanically inclined i was thinkin greddy turbo and my block is getting lower compression pistions 8:01 stainless valves and jus totally redoing my head i need to know good places to buy pistons and engine internals over the net that is cheap and also good at the same tome nad not jus pistons the whole turbo kit Link to comment Share on other sites More sharing options...
cranny Posted November 9, 2006 Share Posted November 9, 2006 why only 8:1? thats pretty low. that engine is little over 9.1:1 stock. you can 8 lbs in that car with stock pistons no problem. buy some eagle H rods , new bearings and ARP rod bolts and your good. Link to comment Share on other sites More sharing options...
nightshift customs Posted November 10, 2006 Author Share Posted November 10, 2006 why only 8:1? thats pretty low. that engine is little over 9.1:1 stock. you can 8 lbs in that car with stock pistons no problem. buy some eagle H rods , new bearings and ARP rod bolts and your good. well in that case then what compression pistions do u recomend and how many pounds of boost do u recomended what psi should i run? Link to comment Share on other sites More sharing options...
cranny Posted November 10, 2006 Share Posted November 10, 2006 leave it the way it is , like i said , throw eagle H piston rods in it with new rod bearings and ARP rod bolts. drive 8 psi to it. 10 if you get it tuned properly. D's are tough man. you can prolly run a tuned 8 psi in it without changing anything in the bottom end , but is it worth the risk of ruining your engine block? wouldnt be for me. Link to comment Share on other sites More sharing options...
nightshift customs Posted November 10, 2006 Author Share Posted November 10, 2006 leave it the way it is , like i said , throw eagle H piston rods in it with new rod bearings and ARP rod bolts. drive 8 psi to it. 10 if you get it tuned properly. D's are tough man. you can prolly run a tuned 8 psi in it without changing anything in the bottom end , but is it worth the risk of ruining your engine block? wouldnt be for me. well my rings are blown so i want new pistons all togather and i want more psi than 8 i want like a 10 second car out of this project Link to comment Share on other sites More sharing options...
Hatch92 Posted November 10, 2006 Share Posted November 10, 2006 well like i said im not to mechanically inclined i was thinkin greddy turbo and my block is getting lower compression pistions 8:01 stainless valves and jus totally redoing my head i need to know good places to buy pistons and engine internals over the net that is cheap and also good at the same tome nad not jus pistons the whole turbo kit 8:1 is waaay to low. to run a car. i can't think of anyone running that low of compression on a turbocharged car well my rings are blown so i want new pistons all togather and i want more psi than 8 i want like a 10 second car out of this project you want to build a 10 sec car? out of a d-series? is that possible. can someone tell me if it is because every 10+ sec honda i've seen are all b-series swaps Link to comment Share on other sites More sharing options...
airjordan223 Posted November 10, 2006 Share Posted November 10, 2006 haha 10 second car, someones been watching the fast an the furious. it could be achieved with a D, but youd be dropping way to much money into it IMO. Link to comment Share on other sites More sharing options...
Hatch92 Posted November 10, 2006 Share Posted November 10, 2006 you can make a 10 sec. car but it's not gonna be very streetable . now if you make a 10 sec d-series......you just got rid of all street drivability Link to comment Share on other sites More sharing options...
