roof leaking
crazymechanic
yo. check how u put your top on you have to watch the side windows weatherstrip you could have bent one in last time u put the top on and it could have leaked through there i would also check the weather stripping..changing it may not be a bad idea.help you also prevent leek if you put your top on wrong again..
thats ok.....the diipcrap i got my sol from went absolutly apecrap with urethane sealant.....i mean its everywhere. all around the weather stripping to the trunk, roof, doors, under the door sills, under the molding on both a pillers.........it took me about 2 and a half weeks just to peal it off the weather stripping....and there are still spots that i cant peal it off with out tearing the stripping......i tell ya some people just should not have cars at all
  • 7 months later...
This topic is now closed to further replies.
