roninzorz Posted September 3, 2006 Share Posted September 3, 2006 I have a 1992 Honda Prelude with an H22A. I just went to the state referee and i failed the smog because my timing was off. I've been to different mechanics and they were worthless....i need to know the timing it has to be at. I cant find it anywhere. Can someone please help me all i need is the timing Quote Link to comment Share on other sites More sharing options...
dannyboy131 Posted September 11, 2006 Share Posted September 11, 2006 Hi does all your timing makes line up on your hrmonic balancer and engine Quote Link to comment Share on other sites More sharing options...
Kastigir Posted September 12, 2006 Share Posted September 12, 2006 16 degress BTDC? Quote Link to comment Share on other sites More sharing options...
mycarsux Posted September 17, 2006 Share Posted September 17, 2006 Bottom Top Dead Center? which one? bottom or top? Quote Link to comment Share on other sites More sharing options...
Kastigir Posted September 17, 2006 Share Posted September 17, 2006 BTDC=Before Top Dead Center Quote Link to comment Share on other sites More sharing options...
cranny Posted September 17, 2006 Share Posted September 17, 2006 15 degrees usually around there. but you have to disable your ecu's ability to compensate before you use a timing gun. could be why your having a prolem. the same 2 pin connector you use to read the codes , you cross it to disable real time timing adjustments. than you can put a timing light on it. Quote Link to comment Share on other sites More sharing options...
mycarsux Posted September 17, 2006 Share Posted September 17, 2006 <---corrected Quote Link to comment Share on other sites More sharing options...
