Masteroftictacs Posted September 1, 2006 Share Posted September 1, 2006 i will be driving my teggy daily and i would like to stomp on it occasionally. it will be NA so no crazy amount of HP. just healthy. i am concerned about wheel hop. the last time i drove it i remember once i hammered it(after i gently leting off on the clutch) at a light from full stop and my front end exhibited "wheel hop". i want to prevent this and/or eliminate this completly. i am still doing research of my own however if any knows of a perticular product or any arrangement of products i would appreciate enlightenment. again goal: healthy NA B18C1 + "?suspension component(s)?"= little to no wheel hop Link to comment Share on other sites More sharing options...
Attaus Posted September 1, 2006 Share Posted September 1, 2006 Traction bar Link to comment Share on other sites More sharing options...
b16bhonda Posted September 1, 2006 Share Posted September 1, 2006 so let me get this straight, you "hammered" it and gently let off the clutch? doesn't make much sense...but if you stop trying to peel out, you won't have wheel hop. to really answer your question, i noticed a little difference when i changed out my shocks/springs...and a huge difference when i went with lsd in the motor swap. Link to comment Share on other sites More sharing options...
Masteroftictacs Posted September 1, 2006 Author Share Posted September 1, 2006 so let me get this straight, you "hammered" it and gently let off the clutch? doesn't make much sense...but if you stop trying to peel out, you won't have wheel hop. to really answer your question, i noticed a little difference when i changed out my shocks/springs...and a huge difference when i went with lsd in the motor swap. how do you get your kicks grandma. jk. thnx for the thread. ok seriously though... you know what i mean i let of the clutch to not catch so hard, brought it up to about 3k rpms then stomped on it "for kicks". vtec fun... but whatever... ok yea i already have my shocks and springs changed out. H and R lowering springs and eibach shocks and about the lsd... wouldn't tht only help wheel spin i.e. traction on one side. my question was directed to torque concerns i just want my wheels to stay on the ground. im allowed to peel out whenever i want. it's fun. Link to comment Share on other sites More sharing options...
b16bhonda Posted September 1, 2006 Share Posted September 1, 2006 how do you get your kicks grandma. i get my kicks at 9000rpms...i'm no grandma lol...like attaus said, traction bar. and yes, lsd will help wheel hop. my sohc motor used to do that all the time, but after the swap it was just perfect. no more hopping...your wheels would stay on the ground. i also got some new tires to add Link to comment Share on other sites More sharing options...
SolLesHonda Posted September 2, 2006 Share Posted September 2, 2006 Motor mount inserts, suspension upgrades, engine torque damper, traction bar, and H brace. Link to comment Share on other sites More sharing options...
Pballer2005 Posted September 2, 2006 Share Posted September 2, 2006 just get a fat guy to sit in the front to add some weight to those wheels Link to comment Share on other sites More sharing options...
90IntegraC1 Posted September 3, 2006 Share Posted September 3, 2006 Motor mount inserts, suspension upgrades, engine torque damper, traction bar, and H brace. dammit mike! i was gonna pwn some clueless n00bs and say that, then you stroll in here and steal my thunder! +12 solid lca's lsd camber kit to name a few other things that could possibly help with you wheel hop. but imo the most important thing are solid motor mount inserts. i bought solid racing mounts for my swap from explicit performance in Washington DC, if i were you that would be the first thing i did.... Link to comment Share on other sites More sharing options...
SolLesHonda Posted September 3, 2006 Share Posted September 3, 2006 Surprisingly enough, the engine torque damper makes a world of difference. Link to comment Share on other sites More sharing options...
90Tegtyper Posted September 10, 2006 Share Posted September 10, 2006 Surprisingly enough, the engine torque damper makes a world of difference. my friend put upper and lower strut bars on the front and the back, and a cpillar bar and and wheel hop went way way down Link to comment Share on other sites More sharing options...
