gfrain Posted July 16, 2006 Share Posted July 16, 2006 engine leaks oil around timing belt cover(about a quart a month) car had new timing belt and cam and balance shaft seals about 10, 000 miles ago, along with water pump, They pretty much did all the seals in that area according to the receipt I havei, Shall we do again and trust the water pump will last ?? any thoughts at all................. thanks Gene Link to comment Share on other sites More sharing options...
Kastigir Posted July 16, 2006 Share Posted July 16, 2006 engine leaks oil around timing belt cover(about a quart a month)car had new timing belt and cam and balance shaft seals about 10, 000 miles ago, along with water pump, They pretty much did all the seals in that area according to the receipt I havei, Shall we do again and trust the water pump will last ?? any thoughts at all................. thanks Gene Sounds like the cam seal is improperly installed. Who did the work? Link to comment Share on other sites More sharing options...
