altaguy Posted July 14, 2006 Share Posted July 14, 2006 I have an 89 Prelude with automatic trans. Recently the S3 light started to flash and the auto trans started to miss 2nd gear on up and downshifts. Now, when I start out in the morning, things go normally for a while and then after the car is warmed up, it starts forgetting it has 2nd gear again and the S3 light starts to flash. I have done some research [manual and Net] and this indicates transmission issues. Some info. I found seems to indicate resetting the TCU by disonnecting the battery sometimes works. Others say change the trans fluid with Honda fluid. Others suggest read the TCU codes by jumping a cable under the dash. I have these questions: 1. Can the TCU be reset by a simple battery cable disconnect on a 89 Prelude? If so, how long should it be disconnected? 2. Should I first attempt to read the TCU codes before resetting it? If so, does anyone know where I can get info on the Net as to what the flashing code numbers mean? 3. What should I do if the TCU is bad? Junkyard replacement? rebuilts? 4. Any other ideas? Thanks in advance for any thoughts. Link to comment Share on other sites More sharing options...
Kastigir Posted July 15, 2006 Share Posted July 15, 2006 I have an 89 Prelude with automatic trans. Recently the S3 light started to flash and the auto trans started to miss 2nd gear on up and downshifts. Now, when I start out in the morning, things go normally for a while and then after the car is warmed up, it starts forgetting it has 2nd gear again and the S3 light starts to flash. I have done some research [manual and Net] and this indicates transmission issues. Some info. I found seems to indicate resetting the TCU by disonnecting the battery sometimes works. Others say change the trans fluid with Honda fluid. Others suggest read the TCU codes by jumping a cable under the dash. I have these questions: 1. Can the TCU be reset by a simple battery cable disconnect on a 89 Prelude? If so, how long should it be disconnected? 2. Should I first attempt to read the TCU codes before resetting it? If so, does anyone know where I can get info on the Net as to what the flashing code numbers mean? 3. What should I do if the TCU is bad? Junkyard replacement? rebuilts? 4. Any other ideas? Thanks in advance for any thoughts. 1. Yes, usually a 10 second disconnect will clear the codes. 2. Absolutely, if somethings wrong you want to fix it. I have nothing for the 2nd part of your question. 3. Always the best bet is to buy a new, OEM replacement. Unfortunately not everybody can afford that, so you go with whichever option is best for you. Remember that typically you get what you pay for. 4. I don't mess with Autos much, so no. Link to comment Share on other sites More sharing options...
ludedude25 Posted July 15, 2006 Share Posted July 15, 2006 I bought a TCU for my girlfirends car on ebay. 3 year warantee. Only cost $138 shipped. The only thing is you have to return your old one for warantee and good feedback, kinda a exchange deal. Immediately after putting in the new one all problems disappeared. Resetting first is a good start. Her car had a LED window on the TCU for reading codes. Link to comment Share on other sites More sharing options...
altaguy Posted July 17, 2006 Author Share Posted July 17, 2006 Ludedude25: We also read the LED light codes that were 7 & 8, which indicate trouble with the 2 separate shift solenoids on the tranny. Do you recall the LED codes that your car was giving? I gotta think it would be rare that BOTH solenoids would go at the same time. Could this point to the TCU box? Dunno, guess I will have to take it to a Honda dealer to let them troubleshoot from here. Thanks for your suggestions. Link to comment Share on other sites More sharing options...
Kastigir Posted July 17, 2006 Share Posted July 17, 2006 Ludedude25:We also read the LED light codes that were 7 & 8, which indicate trouble with the 2 separate shift solenoids on the tranny. Do you recall the LED codes that your car was giving? I gotta think it would be rare that BOTH solenoids would go at the same time. Could this point to the TCU box? Dunno, guess I will have to take it to a Honda dealer to let them troubleshoot from here. Thanks for your suggestions. Rare perhaps, but certainly not impossible. Link to comment Share on other sites More sharing options...
