Thatguyishere Posted July 9, 2006 Share Posted July 9, 2006 so today i noticed that there is moisture and condensation building up in my tailights. whats the best way to fix this? does it mean that my seal is broken and need a new gasket? or what thanks oh yeah, also need to clean one of my headlights, that yellow-ish crap is building up in there, whats a good cleaning solution for them? Link to comment Share on other sites More sharing options...
Attaus Posted July 9, 2006 Share Posted July 9, 2006 For the tail lights, you just need to re-seal them. You can either melt the old seal away and scrape it off, then apply a new one, or just apply a new silicone sealant on top of it. Make sure its rated for heat and stuff in case the temp is hot. For the headlights, use some Meguiars plastic cleaner. Much easier & quicker than wet sanding. Link to comment Share on other sites More sharing options...
99CiViCSi99 Posted July 9, 2006 Share Posted July 9, 2006 yea i have moisture in my headlights... im just gonna buy new ones. there not expensive, so thats always an option for u. Link to comment Share on other sites More sharing options...
BlackH22A4 Posted August 3, 2006 Share Posted August 3, 2006 yea i have moisture in my headlights... im just gonna buy new ones. there not expensive, so thats always an option for u. I used to have a Civic and those headlights are cheap in price. But ludes are more expensive. almost everywhere i go they're always pricey, this is the only spot i can find them for under $300 per headlight brand new. https://www.hondaautomotiveparts.com/auto/j...cgry5=HEADLIGHT I get alot of stock parts from here. very fast shipping and strait from honda. not bad for little things, if you dont want to chance it. Link to comment Share on other sites More sharing options...
90IntegraC1 Posted August 3, 2006 Share Posted August 3, 2006 ^ that's a rip off. go to a junkyard or look on ebay for someone parting out their car....im sure you would find both headlights for around $60 Link to comment Share on other sites More sharing options...
CleanGSR Posted August 3, 2006 Share Posted August 3, 2006 You don't need new headlights. Get a good plastic cleaner and if that doesn't work, get about a 2500 grit sandpaper and wetsand them. If the 2500 isn't working slowly increase the grit. When it's finally done, work your way down to a 3000 grit and then buff them really well. They'll look like new. You can hand buff them too, with the proper compound as long as you have lots of elbow grease. Link to comment Share on other sites More sharing options...
