89crxsi1003 Posted July 8, 2006 Share Posted July 8, 2006 i was woundering in some of my other cars u have a access door in the trunk to change the fuel pump.Im woundering do crx's have this or do u have to drop the tank to access it???? Thanks. Link to comment Share on other sites More sharing options...
sloassrex Posted July 10, 2006 Share Posted July 10, 2006 I'm not sure, but I think if you pull everything off of where the rear is. I think that there is an access door there. But don't try this until somebody else confirms my info. Link to comment Share on other sites More sharing options...
cranny Posted July 10, 2006 Share Posted July 10, 2006 yeah under the back cargo door area where back seats would be. the filler neck and that goes in there. you can get to it there. Link to comment Share on other sites More sharing options...
89crxsi1003 Posted July 11, 2006 Author Share Posted July 11, 2006 yeah under the back cargo door area where back seats would be. the filler neck and that goes in there. you can get to it there. thanks cranny apprecitate the help. Can u change the fuel pump from there? the problem im haveing is i just did a complete rebuild but i bought the car with it already started and ive never heard it run so dont know if the fuel pumps any good but going to use a test light to see if i have power to it. Link to comment Share on other sites More sharing options...
cranny Posted July 11, 2006 Share Posted July 11, 2006 check it for power like you say , fuel pumps dont go that regularly from my experience. Link to comment Share on other sites More sharing options...
Joe W Posted July 13, 2006 Share Posted July 13, 2006 i'd probably change it out for a new one but youll have to take the tank out cause that center piece isnt the pump it is on the left side of the tank. I had some fuel problems and ended up replacing mine it was coated in rust and just looked awful. Not a hard job just takes some time and i recommend using gas cans to catch that expensive gas. Also check your main relay which is under the dash near the hood lever. Not an expert but ive done everything i suggested to mine and it runs like a charm now Link to comment Share on other sites More sharing options...
89crxsi1003 Posted July 18, 2006 Author Share Posted July 18, 2006 i wanna go with a walbro 255 but right now its stock except for some bolt ons but have a turbo kit that im installing when i get it running right. Can i run the walbro on a stock motor??? Link to comment Share on other sites More sharing options...
