how do i....
chargedxtreme
Hey man, I don't know but when you find out, could you pm me. Thanks a lot.
:rolleyes: , see heres how i did it, being as a didnt need the tranny that i pulled at all. I just slid the rubber dust cover away, then took a really cool grinder and cut it at the tranny, tranny was junk anyway, then im going to pull the motor, and drill out that hollow mushroomed fitting,, if i can. ill keep you updated
how do i separate the shift linkage from the tranny? i did a search and couldnt find chit. should i just drill out that mushroomed hollow fitting and replace it witha nut and bolt?
1 GET PUNCH AND HAMMER
2 PULL DUST COVER BACK
3 THERE IS A C CLAMP THING POP OFF WITH FLAT HEAD
4 HIT PIN WITH PUNCH AND HAMMER
