Bullhead Posted July 7, 2006 Share Posted July 7, 2006 How do you check if your IACV is going bad and is there a fix if its bad? Tia Dave B18B1 Link to comment Share on other sites More sharing options...
SolLesHonda Posted July 7, 2006 Share Posted July 7, 2006 Behind your IM there is a valve that you can just with a flat head. make sure it's tight. I had to replace mine. Link to comment Share on other sites More sharing options...
Bullhead Posted July 8, 2006 Author Share Posted July 8, 2006 Behind your IM there is a valve that you can just with a flat head. make sure it's tight. I had to replace mine. What is "IM"? I new here. I did take the IACV off an cleaned it out although it didn't look that bad. I reinstalled it but no difference. More specifically, at cold start the idle surges from aprox. 1000 to 1500 rpm untill its warm. Another problem is that when I let go of the gas obruptly the idle return to 1000 rpm them bounces back to 1300 rpm and back to 1K rpm. I know the idle is too high but I'm trying to take one problem at a time unless they are related. I just acquired this car an the PO (Previous Owner) now has amnesia reguarding the vehicles history. Any help is very appreciated Thanx in advance Link to comment Share on other sites More sharing options...
90IntegraC1 Posted July 8, 2006 Share Posted July 8, 2006 IM=Intake Manifold it's the small compartment in which the intake tubing takes you tooooo, then there's teh throttle body, then teh IM edit: oh and the bouncing tach...my car did that for a while and i replaced the distributer/rotor and it stopped. Link to comment Share on other sites More sharing options...
Bullhead Posted July 9, 2006 Author Share Posted July 9, 2006 Well I swapped the distributor with a friend an no change was noticed. I tried to adjust the idle at the IM (Throttle body), but it won't adjust the idle down only higher. I even swapped the idle screw with a friend and no change. Can the throttle body be the culprit being the the idle adjustment screw didn't adjust the idle down? I also cleaned the FITV. The result were the cold start corrected for now. Will recheck when the engine cools down. Link to comment Share on other sites More sharing options...
cranny Posted July 10, 2006 Share Posted July 10, 2006 as solles said its definitely either your IACV , your EGR valve getting plugged up , or maybe its your purge solenoid(part of your evap system) ive seen that cause idle issues. im betting on IACV. your describing its exact symptoms dude right down to the hitting the gas having it drop down and start doing it again. Link to comment Share on other sites More sharing options...
Snojet Steve Posted July 18, 2006 Share Posted July 18, 2006 Mine is doing it now, going down to 1000 then rising to 1500 when warm. I am thinking EGR valve. Link to comment Share on other sites More sharing options...
2001teg Posted August 7, 2006 Share Posted August 7, 2006 Usually honda engine surge is from a cooling problem, motor may be getting too hot Link to comment Share on other sites More sharing options...
90Tegtyper Posted October 21, 2006 Share Posted October 21, 2006 found out the problem under the throttle body there is a valve with 2 coolant hoses goin into it they are prett small ones. on the back of the valve there a to "8mil" bolts. there are 3 "10mil" bolts holding the valve on. take them off then disconnect the coolant hoses. take the back cover off which the 2 8mil bolts are holding on. there is a white plastic screw type thing in there now take a flat head and tighten it all the way then back it out one turn then put honda bond or superglue around it so that the screw wont back it self out from the pressure of the motor. Link to comment Share on other sites More sharing options...
cranny Posted October 22, 2006 Share Posted October 22, 2006 Usually honda engine surge is from a cooling problem, motor may be getting too hot if you read better they said at startup meaning cold. found out the problem under the throttle body there is a valve with 2 coolant hoses goin into it they are prett small ones. on the back of the valve there a to "8mil" bolts. there are 3 "10mil" bolts holding the valve on congrats , thats called an iacv like you were told , lol , good job man. Link to comment Share on other sites More sharing options...
90Tegtyper Posted October 22, 2006 Share Posted October 22, 2006 if you read better they said at startup meaning cold.congrats , thats called an iacv like you were told , lol , good job man. Link to comment Share on other sites More sharing options...
90Tegtyper Posted October 22, 2006 Share Posted October 22, 2006 idle air is on the backside horizontally on the IM, the fitv is vertical on the IM (assuming that your looking at it in the front to the back) lol Link to comment Share on other sites More sharing options...
90Tegtyper Posted October 22, 2006 Share Posted October 22, 2006 also after fixing the FITV then you can adjust the idle lower, that will fix your problem Link to comment Share on other sites More sharing options...
cranny Posted October 30, 2006 Share Posted October 30, 2006 i cant beleve i have to say this again. NEVER TOUCH THE IDLE SCREW ON A FI CAR , UNLESS PREVIOUSLY ALTERED. Link to comment Share on other sites More sharing options...
Hatch92 Posted October 31, 2006 Share Posted October 31, 2006 ^ +1. Link to comment Share on other sites More sharing options...
90Tegtyper Posted November 1, 2006 Share Posted November 1, 2006 i cant beleve i have to say this again. NEVER TOUCH THE IDLE SCREW ON A FI CAR , UNLESS PREVIOUSLY ALTERED. hmm so you are telling me that after fixing the FITV and the idle more than likely goin down to about 500 or it could be at like 1.2 that not to mess with it , and for the record i didnt say "turn the idle screw" and nothing else, I had a different statement if i recall, no point in a war just dont correct me when your not correcting me correctly. thanks Link to comment Share on other sites More sharing options...
