Yawn Posted July 3, 2006 Share Posted July 3, 2006 My First Post (Newbie here) I am replacing the head gasket of my 94 civic and I just want to know the best way to clean the mating surface (cylinder head & block). This is the first time I am going to do this kind of job on my car. I know I am not suppose to use any abrasives since head is made of aluminum. A friend told me to scrape it using using a sharp blade. Thanks in advance. Link to comment Share on other sites More sharing options...
sohcVTEC-E Posted July 3, 2006 Share Posted July 3, 2006 Sharp blade is what you should use. Make sure not to drop any into the cylinders. You don't wanna score the walls. Link to comment Share on other sites More sharing options...
Hatch92 Posted July 4, 2006 Share Posted July 4, 2006 yea....use a razor blade to scrape it off... Link to comment Share on other sites More sharing options...
Yawn Posted July 4, 2006 Author Share Posted July 4, 2006 after using the sharp blade, I can still see some marking of the old gasket on the surface. How am I suppose to remove these markings. I don't want to keep on using the sharp blade since I might damage the surface. Can I use something like paint thinner or acetone to remove these marking left? Link to comment Share on other sites More sharing options...
Hatch92 Posted July 4, 2006 Share Posted July 4, 2006 try using thinner but u don't want to get that down any of the cylinders....that would cause some problems Link to comment Share on other sites More sharing options...
cranny Posted July 4, 2006 Share Posted July 4, 2006 use thinner and a dish sponge with a scrubbing surface on one side. works good(minimizing the amount you spill into bottom end of course). if this still isnt getting it all off for ya , than use a scotchbrite pad with fast long strokes. also , the sleeves arent alluminum. so you can wirewheel them with a soft brass one and id recommend it for a nice new seal. just need good control over your grinder or drill as to not knick alluminum surface. Link to comment Share on other sites More sharing options...
Yawn Posted July 4, 2006 Author Share Posted July 4, 2006 should I clean both mating surfaces until they are shiny or some gasket marks left will be ok? I don't know if I should clean it up until no marks are left on the surfaces. I am trying to run my finger across the surface trying to feel any bumps and it seems it's pretty smooth even if marks are still present. Link to comment Share on other sites More sharing options...
cranny Posted July 4, 2006 Share Posted July 4, 2006 if its smooth to the touch as best as you can get it than its fine fire it together. Link to comment Share on other sites More sharing options...
Yawn Posted July 6, 2006 Author Share Posted July 6, 2006 How am I suppose to know which side of the head gasket go to cylinder head and which side for the engine block. One side is different from the other side. Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted July 6, 2006 Share Posted July 6, 2006 Your name made me tired, Im out. Good night. Link to comment Share on other sites More sharing options...
HONDA CRX 88 SI Posted July 6, 2006 Share Posted July 6, 2006 lol me to but lets keep on the topic. Link to comment Share on other sites More sharing options...
Yawn Posted July 6, 2006 Author Share Posted July 6, 2006 Your name made me tired, Im out. Good night. lol. Not my name, it was your avatar that made you tired. I hope by the time you go online tomorrow you have the answer to my question. Link to comment Share on other sites More sharing options...
HONDA CRX 88 SI Posted July 6, 2006 Share Posted July 6, 2006 naw his avatar those not make me tired it brings back memories of some things. i did Link to comment Share on other sites More sharing options...
cranny Posted July 6, 2006 Share Posted July 6, 2006 let me see ahhh , it can only go on one way monkey ass , lol. now git er done. Link to comment Share on other sites More sharing options...
