REDLINEperformance Posted July 2, 2006 Share Posted July 2, 2006 Every time I floor the gas on my 2000 civic si, it bogs out and engine tends to shut off. Theres no check engine light on. Ive changed out the spark plugs, wires, fuel filter, even added some intake headers exhaust, and it still bogs out. What could it be?!!!! HELP ME, HELP ME PLEASE! Link to comment Share on other sites More sharing options...
sohcVTEC-E Posted July 2, 2006 Share Posted July 2, 2006 I'd say maybe bad gas or dirty injectors Link to comment Share on other sites More sharing options...
REDLINEperformance Posted July 3, 2006 Author Share Posted July 3, 2006 It drives fine when I drive normal though. Its just whenever I gas it hard, it bogs out and dies. I even used fuel system treatment cleaner, it still does it. Link to comment Share on other sites More sharing options...
sohcVTEC-E Posted July 3, 2006 Share Posted July 3, 2006 Fuel pump maybe? I have no clue man. Wish I could be more of a help. Link to comment Share on other sites More sharing options...
Hatch92 Posted July 4, 2006 Share Posted July 4, 2006 sounds like ur gettin 2 much fuel, and not enought air, or too much air and not enough fuel... Link to comment Share on other sites More sharing options...
Secksi Posted July 4, 2006 Share Posted July 4, 2006 does it do it as your RPM's hit a certain point or just from putting the petal down? If its shutting down with the high RPM's then change out your Coil. If not i would say sounds like injectors. Link to comment Share on other sites More sharing options...
cranny Posted July 4, 2006 Share Posted July 4, 2006 might be your dizzy as well. if it was a sensor(something to do with fuel and air delivery), youd be getting a light. id bet on something in your dizzy. Link to comment Share on other sites More sharing options...
blk99SI Posted July 5, 2006 Share Posted July 5, 2006 Every time I floor the gas on my 2000 civic si, it bogs out and engine tends to shut off. Theres no check engine light on. Ive changed out the spark plugs, wires, fuel filter, even added some intake headers exhaust, and it still bogs out. What could it be?!!!! HELP ME, HELP ME PLEASE! Try distributor cap and new injectors... Most likely it will one of the two...Distributor caps are pretty cheap too so I suggest going with that route first Link to comment Share on other sites More sharing options...
sohcVTEC-E Posted July 5, 2006 Share Posted July 5, 2006 Woah woah woah. Maybe new dizzy cap and CLEAN his factory injectors. EDIT- My bad, he already tried cleaning them. Sorry... Link to comment Share on other sites More sharing options...
cranny Posted July 5, 2006 Share Posted July 5, 2006 could be a CPS(crank position sensor) as well. located under lower plastic timing belt cover , next to crank timing belt pully. Link to comment Share on other sites More sharing options...
SolLesHonda Posted July 5, 2006 Share Posted July 5, 2006 Definitely could be, it's just not everyday that something like that decides to go on ya. Link to comment Share on other sites More sharing options...
REDLINEperformance Posted July 8, 2006 Author Share Posted July 8, 2006 Thanks for all the feedback guys, but I found the problem. It was a bad distributor. I changed out the cap and rotor but didnt change out the coil. It was the coil the whole time. Thanks for ya help guys! Link to comment Share on other sites More sharing options...
blk99SI Posted July 10, 2006 Share Posted July 10, 2006 could be a CPS(crank position sensor) as well. located under lower plastic timing belt cover , next to crank timing belt pully. That should throw a check engine light if it was a sensor Link to comment Share on other sites More sharing options...
cranny Posted July 11, 2006 Share Posted July 11, 2006 true enough. but ive seen them go and not get an engine light. only that sensor ive seen do it. Link to comment Share on other sites More sharing options...
