TXCatalyst Posted July 2, 2006 Share Posted July 2, 2006 I bought this car used and am trying to add a/c. It's 98 Civic DX Hatchback with b16a2 - I have an a/c compressor which I thought was from a 98 DX, but it's a few millimeters off for the bracket. Is it a good assumption, I must buy a 99-2000 Civic SI a/c compressor ? I wasn't aware that Honda would change the a/c compressors for the 6th gens?? Or is it because it is a different motor entirely ? Which a/c compressor should I get for a B16a2 ? Link to comment Share on other sites More sharing options...
cranny Posted July 2, 2006 Share Posted July 2, 2006 you can use your compressor but youl need B16 brackets for the engine block. you might need spacers like washers to get pulleys to align properly. i added P/S to a B16 swapped integra did same thing im telling you , B16 brackets , the original pump. Link to comment Share on other sites More sharing options...
Bullhead Posted July 10, 2006 Share Posted July 10, 2006 you can use your compressor but youl need B16 brackets for the engine block. you might need spacers like washers to get pulleys to align properly. i added P/S to a B16 swapped integra did same thing im telling you , B16 brackets , the original pump. Does it also apply to a b18b1 in a 95 civic-hb? I do have the b18b1 a/c bracket :bow: Link to comment Share on other sites More sharing options...
