t_ravis424 Posted June 29, 2006 Share Posted June 29, 2006 I have a 1991 Honda Accord. The Turn Signals have completely stopped working, the green blinking arrow on the dashboard won't come on and the front and rear turn signals won't work. I took it to an auto shop and they said it might be the flasher, but its not, because I tried that. Any help would be much appreciated! Link to comment Share on other sites More sharing options...
muymula Posted July 2, 2006 Share Posted July 2, 2006 Do they go on when you hit your hazard switch button? If not, that's the problem. The signals are routed through the hazard switch, and when it's bad the signals won't work either. It's about 27$ for a switch Nick I have a 1991 Honda Accord. The Turn Signals have completely stopped working, the green blinking arrow on the dashboard won't come on and the front and rear turn signals won't work. I took it to an auto shop and they said it might be the flasher, but its not, because I tried that. Any help would be much appreciated! Link to comment Share on other sites More sharing options...
t_ravis424 Posted July 3, 2006 Author Share Posted July 3, 2006 Do they go on when you hit your hazard switch button? If not, that's the problem. The signals are routed through the hazard switch, and when it's bad the signals won't work either. It's about 27$ for a switchNick When the hazard light button is pressed the lights on the dash and on the outside of the car both work fine. Link to comment Share on other sites More sharing options...
Humphries Posted July 3, 2006 Share Posted July 3, 2006 i think it might be the fuse to the indicators. Link to comment Share on other sites More sharing options...
trich Posted July 20, 2006 Share Posted July 20, 2006 I contacted a repair shop, and they said I needed a $200 diagnostics check to see where the bad fuse is? Is this worth the money Link to comment Share on other sites More sharing options...
CRG7 Posted July 21, 2006 Share Posted July 21, 2006 I contacted a repair shop, and they said I needed a $200 diagnostics check to see where the bad fuse is?Is this worth the money No. Look under your steering column, remove the fuse panel cover, look at it to see where the fuse is located, pull it out, see if it's burnt out. Link to comment Share on other sites More sharing options...
