93 civic hatch Posted June 18, 2006 Share Posted June 18, 2006 My car overheated and I blew a headgaskit.I put a new radiator ,cap,and hoses, got the head check for cracks and shaved,It's all back together and now its smoking,It doesn't smoke all the time so I know it's not a piston ring problem,compression is perfect. No check engine light so I don't think its a bad sensor. It doesn't idle weird and the car has never run better except for this FU!%#ING smoke. I think maybe it's a loose valve guide or somthing......Any ideas....I'm losing my mind 93civic hatch Link to comment Share on other sites More sharing options...
Rick B. Posted June 18, 2006 Share Posted June 18, 2006 My car overheated and I blew a headgaskit.I put a new radiator ,cap,and hoses, got the head check for cracks and shaved,It's all back together and now its smoking,It doesn't smoke all the time so I know it's not a piston ring problem,compression is perfect. No check engine light so I don't think its a bad sensor. It doesn't idle weird and the car has never run better except for this FU!%#ING smoke. I think maybe it's a loose valve guide or somthing......Any ideas....I'm losing my mind 93civic hatch how much smoke, what color is the smoke. you might jus be burning oil Link to comment Share on other sites More sharing options...
93 civic hatch Posted June 18, 2006 Author Share Posted June 18, 2006 it smokes when i'm on the throttle ,like at the end of the gears,I am burning oil.When i'm cruisen in 4th n 5th there is no smoke if I let off the gas for a few secs then press it again ,smoke Link to comment Share on other sites More sharing options...
cranny Posted June 18, 2006 Share Posted June 18, 2006 definitely valve seals dude. Link to comment Share on other sites More sharing options...
Hatch92 Posted June 18, 2006 Share Posted June 18, 2006 +1, valve seals Link to comment Share on other sites More sharing options...
Timmythewop89 Posted June 19, 2006 Share Posted June 19, 2006 93 civic if the smoke is blue then its valve seals most likely, but you still havent said which color. Link to comment Share on other sites More sharing options...
93 civic hatch Posted June 19, 2006 Author Share Posted June 19, 2006 It's kinda blue/grey Link to comment Share on other sites More sharing options...
93 civic hatch Posted June 19, 2006 Author Share Posted June 19, 2006 How much do machine shops charge for valve jobs.I check one place they said about 2 hundred Link to comment Share on other sites More sharing options...
93 civic hatch Posted June 19, 2006 Author Share Posted June 19, 2006 Supposing there was alot of oil and antifreeze trapt in the muffler from when i blew the headgaskit ,how long would it take to burn away.I'm pretty sure thats not the problem but I have to hope.Just a friend of mine was having the same problem after a head gaskit and just bought a new exhaust system and the problem dissapeared Link to comment Share on other sites More sharing options...
cranny Posted June 19, 2006 Share Posted June 19, 2006 thats an exspensive way to trial and error dude , lol Link to comment Share on other sites More sharing options...
Timmythewop89 Posted June 19, 2006 Share Posted June 19, 2006 blue and grey? what the hell were you doin to that motor? Link to comment Share on other sites More sharing options...
