monstersol Posted June 14, 2006 Share Posted June 14, 2006 can anyone help me, my del sols boot (trunck) is stuck ive replaced the motor but there doesnt seem to be any power going to the new one? the ecu works on my friends del sol so i dont think its that?! i think it might be an electric fault? anyone got any ideas or help? peter Link to comment Share on other sites More sharing options...
redcoats1976 Posted June 14, 2006 Share Posted June 14, 2006 check for power at the motor with a tester(like sears sells) if there is no power check the fuse...in fact check the fuse block for corrosion,clean it if you have to,and get a new fuse.not sure when i think about it if this is a relay or a fuse,but thats what i would suspect. Link to comment Share on other sites More sharing options...
redcoats1976 Posted June 14, 2006 Share Posted June 14, 2006 BTW if your friends sol is the same as yours maybe he would let you borrow his relay to check it first,they are probably not too cheap and i wouldnt want to replace the wrong part... Link to comment Share on other sites More sharing options...
