Tensai Posted June 13, 2006 Share Posted June 13, 2006 I recently bought a 2006 Accord LX-SE MT. It has a factory installed 6-disc in dash cd changer, but the stereo has no auxiliary inputs (that i can see). I would like to find a way to hook up an mp3 player or dvd player and have it play through the car's speaker system. I have tried using both an FM radio transmitter and an FM wired transmitter and was not impressed. Does anyone know of any way I can create this auxiliary line in? Link to comment Share on other sites More sharing options...
dcletten Posted June 13, 2006 Share Posted June 13, 2006 not a clue, prolly easiest(maybe not cheapest) way to do it would be buy a flip out dvd player with an aux input Link to comment Share on other sites More sharing options...
CleanGSR Posted June 13, 2006 Share Posted June 13, 2006 You can buy CD players for 200 bucks that have the aux input, but I get the impression that he doesn't want to swap out his stock system. Link to comment Share on other sites More sharing options...
Tensai Posted June 13, 2006 Author Share Posted June 13, 2006 Correct, I installed a new head unit in my previous car that came with Aux in, but I'd prefer to keep the installed stereo in this case. Link to comment Share on other sites More sharing options...
CleanGSR Posted June 13, 2006 Share Posted June 13, 2006 I'll research it for you a little bit, cause I wouldn't mind having that on my car too. I'll post in here if I find anything. Link to comment Share on other sites More sharing options...
nguyenpd Posted June 17, 2006 Share Posted June 17, 2006 the 6 disc does have an aux input...you have to buy an adapter for it thats about 100 bucks. i put one in my car and my cousins http://www.logjamelectronics.com/sounsnhond3.html Link to comment Share on other sites More sharing options...
Mobius_01 Posted August 20, 2006 Share Posted August 20, 2006 Hmm, any info on how to remove the actual factory radio so I can install the SNHond3? Link to comment Share on other sites More sharing options...
GesusNY Posted September 14, 2006 Share Posted September 14, 2006 I recently bought a 2006 Accord LX-SE MT. It has a factory installed 6-disc in dash cd changer, but the stereo has no auxiliary inputs (that i can see). I would like to find a way to hook up an mp3 player or dvd player and have it play through the car's speaker system. I have tried using both an FM radio transmitter and an FM wired transmitter and was not impressed. Does anyone know of any way I can create this auxiliary line in? The iPod integrator by USA*SPEC is my recommendation for a clean, neat, and cable free iPod integration. It allows you to control your ipod through the steering wheel controls as well as from the iPod itself if you so choose. The USA*SPEC comes with an optional cable that allows you another AUX input. If you already have XM radio (or a button that allows you to switch to XM) you already have an AUX input. XM radio uses the one AUX input in the Honda factory head unit. If you hate XM like I do you can simply purchase the USA*SPEC integrator and swap out the XM plug for the iPod plug. But if you want to make use of the AUX button on the head unit you need to purchase the optional cable so that you can take the one AUX input in the head unit and split it between the USA*SPEC and the other thing. I hate XM so I simply swapped out the cable. Link to comment Share on other sites More sharing options...
magreb Posted January 9, 2007 Share Posted January 9, 2007 Hmm, any info on how to remove the actual factory radio so I can install the SNHond3? You can use this link http://www.handaaccessories.com/accord/06-accord-audio.pdf to gain access to the underside of the 6disc player. I've got an '05 and by following these similar instructions to gain access, I was able to plug the SNHond3 into the port on the bottom of the player where an XM unit or the unit described in the link would go. Hope this helps. Link to comment Share on other sites More sharing options...
