Grizzled Posted May 24, 2006 Share Posted May 24, 2006 B18B1 - 2000 Integra RS/LS/GS 1.8 16V DOHC PGM-FI 1834cc 142hp@6300rpm 127tq@5200rpm B18C1 - 2000 Integra GS-R 1.8 16V DOHC VTEC PGM-FI 1797cc 170hp@7600rpm 128tq@6200rpm I had thought they were pretty close to the same motor, but from looking at the specs and prices they obviously aren't. I'm just curious, not about to run out and buy anything, but other than the VTEC, there must be some differences. Any of you have some time to enlighten me? Bored at work, thanks~ Link to comment Share on other sites More sharing options...
cranny Posted May 24, 2006 Share Posted May 24, 2006 i wouldnt say VTEC is the difference , id say the heads are totally different. Link to comment Share on other sites More sharing options...
Nancy Posted May 24, 2006 Share Posted May 24, 2006 i think the compression on the LS is something like 9.2:1 and the GSR is 10.0:1. someone correct me if im wrong. Link to comment Share on other sites More sharing options...
Ben. Posted May 27, 2006 Share Posted May 27, 2006 i think the compression on the LS is something like 9.2:1 and the GSR is 10.0:1. someone correct me if im wrong. Compression on the LS IS lower, one of the reasons it responds well to boost on a stock block, although the rods are mush. Link to comment Share on other sites More sharing options...
xalexjx@yahoo.com Posted May 27, 2006 Share Posted May 27, 2006 c's are easier and cheaper to get parts from, b's are more rare though Link to comment Share on other sites More sharing options...
sohcVTEC-E Posted May 27, 2006 Share Posted May 27, 2006 I disagree alex. Link to comment Share on other sites More sharing options...
xalexjx@yahoo.com Posted May 27, 2006 Share Posted May 27, 2006 and people steal type r's and re sell them,, go with the c, imo theres a lot more aftermarket parts for them, thats just my input though Link to comment Share on other sites More sharing options...
cranny Posted May 27, 2006 Share Posted May 27, 2006 easier to get parts for alex , i dont know about cheaper. B1 bottom ends are bulletproof man and capable of big power without VTEC. Link to comment Share on other sites More sharing options...
mountaindewguy Posted May 28, 2006 Share Posted May 28, 2006 alex, go away. LS parts are not rare, and they're a dime a dozen. Link to comment Share on other sites More sharing options...
Grizzled Posted May 30, 2006 Author Share Posted May 30, 2006 so basically the head and internals are different, but they have the same block and bore size... correct? Link to comment Share on other sites More sharing options...
mountaindewguy Posted May 30, 2006 Share Posted May 30, 2006 bore size, same different cranks different rods different pistons (still same bore though) better rod bolts on the VTEC model better oil pump setup on the VTEC model for the head, COMPLETELY different of each other. VTEC head is capable of higher RPM's and i believe also the rocker arms are stronger too. their setup is different as well. and the VTEC makes a HUGE difference between the 2, besides the compression. if you're not going to turbo it, the c1 is the better choice. Link to comment Share on other sites More sharing options...
FlyByZTYler Posted June 7, 2006 Share Posted June 7, 2006 OK, it all depends on what you want to do with the motor, B18C1 great for all motor buildups, gets good power fairly strong motor and tons of potential. B18B1 Pretty good for boosting the lower compression means you can booste it a little higher than you can with a b18c on stock pistons, BUT heres the catch my friends the b18b was ment for the GS/RS/LS models which are not performance models so it wasn't build for much modification the piston rods and cranks then to not hold up so well. B18C1&B1 parts are almost equilly as available B18b1 a bit easier to find crappy parts(cuz mostly high schoolers drive them cuz well, thier cheeper than a GSR or they just dont know any better) Honestly I suggest getting the B18C1 it has the most potential for power out of any B series that I've seen esspecially when running all motor. I love mine Man I wrote alot here didn't I...I need a life Link to comment Share on other sites More sharing options...
cranny Posted June 7, 2006 Share Posted June 7, 2006 dude you dont know what your talkin about. a B1 engine can take just as much or more heat than a C1. a B1 is still a performance engine dude , arent all integras sports cars? just cause it doesnt have a VTEC head doesnt mean its not a performance engine. the internals are the same really minus the quality of the parts themselves. head is biggest difference of course. the rockers on a C1 ride on a post that goes from one side of the head to the other(all exhaust valves ride on one , all intakes ride on another). and this provides a fulcrum joint . basically doing the job with very little friction(check some pics youl see what i mean). the B1 head doesnt incorporate this technology. to put it simpler , the DOHC VTEC engines come factory with roller rockers(sort of). and this difference alone , along with tighter valve springs of course , is what allows the VTEC engines to have a higher redline. everything in a B1 can turn 8000 rpm as well except for the valve train. the reason we need to change the springs in order to open and close the valves further and longer(more lift and duration or bigger cams) , is cause the valves cant close fast enough to get ready to get opened again. Link to comment Share on other sites More sharing options...
Rick B. Posted June 16, 2006 Share Posted June 16, 2006 i wouldnt say VTEC is the difference , id say the heads are totally different. well the b18c1 has two stages of vtec which is a huge thing in vtec motors. also, if you do go with the gsr motor, go with an obd1, the later models arent as impressive. Link to comment Share on other sites More sharing options...
cranny Posted June 16, 2006 Share Posted June 16, 2006 2 stages of VTEC? i dont think so dude. man you need to do some msn searches at the very least , lol , just kiddin man. VTEC has 2 stages period , primary and secondary(VTEC). thats it. except VTEC-E , like my D17A2(some will argue its not a VTEC-E engine but those are people who dont know what there talkin about). if the camshaft on a SOHC engine has 5 lobes per cyl. than it is a VTECII engine. if it has 4 , and is a VTEC engine , its a VTEC-E. a D17A2 has 4 lobes per cyl.(VTEC-E) , outside 2 lobes are exhaust(1 for each valve), than 2 in the middle that are different profiles. one small one big. with VTEC not engaged , one intake valve rides on the VTEC lobe , which it does all the time , in VTEC-E engines one intake valve rides on the VTEC lobe all the time , the other valves rocker rides on the smaller profile lobe. when VTEC engages , the smaller profile rocker locks onto the rocker that always rides on the VTEC lobe. in VTECII engines , outside lobes are both exhaust , next 2 lobes inside of exhaust are intake lobes(one for each valve seperately) , and one big lobe in the middle .when VTEC engages , the 2 intake rockers lock on to a center rocker which rides them both on the VTEC lobe. Link to comment Share on other sites More sharing options...
HONDA CRX 88 SI Posted June 17, 2006 Share Posted June 17, 2006 sweet u do look like u spend alot of time on msn. lol jk homes. Link to comment Share on other sites More sharing options...
