hondaeater Posted March 7, 2006 Posted March 7, 2006 ok well i bought sr16ve to go into my nissan nx2000. i have summit multi switching units to activate the cams. but i also have a VAFC. i was searching on the forum but i havent found anything yet. so i figured ide ask do the VTEC soliniods have constant 12v and activate the cam timing by switched ground? or is th the other way around?? also can i control the solinoids by wiring the vafc to a relay then to the solinoids?? thanks for the help and sorry for the noob questions.
CleanGSR Posted March 7, 2006 Posted March 7, 2006 VTECH solenoid? Is this some kind of automated answering system for your phone?
hondaeater Posted March 7, 2006 Author Posted March 7, 2006 sorry the "h" is a habit.....either way do you have an answer or are you just here to point out i dont know crap about hondas?
CleanGSR Posted March 7, 2006 Posted March 7, 2006 No, the VTEC solenoid get's power to it to activate it not a switched ground. There are a lot of things that play into the vtec besides just clicking it on.... i.e. oil pressure, fuel and ignition curves etc. I'm not sure how you plan on putting VTEC on a Nissan since the motor itself doesn't actually have VTEC.
hondaeater Posted March 7, 2006 Author Posted March 7, 2006 No, the VTEC solenoid get's power to it to activate it not a switched ground. There are a lot of things that play into the vtec besides just clicking it on.... i.e. oil pressure, fuel and ignition curves etc. I'm not sure how you plan on putting VTEC on a Nissan since the motor itself doesn't actually have VTEC. its not vtec its nissans vvl......http://sr20forum.com/showthread.php?t=70960 theres a link on how it works. with the way that we do it, we normally use greddy mss or msd switches which i have. i was just wondering about the vafc cause i picked it up for a decent price but if i cant use it ill just sell it and get something else.
CleanGSR Posted March 7, 2006 Posted March 7, 2006 So you're wanting to use a honda VTEC solenoid to activate the vvl on a nissan? Don't know how that will work. If your actually talking about the equivalent of a VTEC solenoid in a Nissan setup, then I have no clue.
blackdelsol Posted March 7, 2006 Posted March 7, 2006 it won't work. don't try to mix breeds in that type of modification. either get all nissan or all Honda setup, but mixing them will only give you problems.
hondaeater Posted March 8, 2006 Author Posted March 8, 2006 no im using 100% nissan parts..... the VAFC is specifically for the honda vtec though. so i was trying to find out basically if the vafc would control my vvl. and how your solinoids were activated.
